Old 07-18-2009, 01:13 PM   #1
mothertrucker424
mothertrucker424's Avatar
springtech problems?
i ordered my brother a springtech upper control arm/coil/shackle/shock 3" lift kit for a s10 2wd
so when i got it there were no instructions but its basic science to install (also came with metal plates and no rear shocks)
i called and they said that they don't make instructions and im suppose to weld the metal plates to upper control arms which sounds weird but i asked if i could talk to someone they didn't have anyone that knew
so i installed the control arms that the bushings didn't fit too well in and now they rub the rim and upper coil mount
i checked caster and wheel is centered so i don't see it being flipped to wrong side (ive seen that on s10 and wheel wont turn due to rubbing/ to much +caster)
has anyone else had any other problems?
i was going to order spindles for for my brothers s10, a set for my silverado and a buddy wanted a set for his but i can't see them making good enough parts
also getting ahold of them is a task in its self
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
1972 K10 4"lift 33"tires (soon to be bigger and better)
2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's
mothertrucker424 is offline   Reply With Quote
Old 07-18-2009, 05:48 PM   #2
Re: springtech problems?
I`ve never even heard of that company.Sounds like they need to go away.Where`s the tech in Springtech?
Old 07-19-2009, 08:53 AM   #3
mothertrucker424
suspension max sells them and ebay
Old 07-19-2009, 11:08 AM   #4
Never heard of Suspension Max either.
who sells them on Ebay?
Old 07-19-2009, 11:21 AM   #5
mothertrucker424
just little companys
springtech has lowering kits /lift kits but nothing worth using if it doesn't fit
Old 07-19-2009, 02:34 PM   #6
70 beast
Certified Hobbiest
70 beast's Avatar
should check out s10 forum or dezertdimes.com.
there a couple places that have alot of info on 2wd s10s.
70 beast is offline   Reply With Quote
Old 07-25-2009, 06:34 PM   #7
mothertrucker424
i emailed another shop they said they don.t include instructions and to cut upper coil perch and weld in metal tab
Thread Tools
Display Modes
