Old 07-21-2009, 11:23 PM   #1
diggy
Will an entire G1 drivetrain from a 69' SB pickup, fit on an 85' Blazer frame?
69'
FRT = D44 with crossover steering, 2.5" Tuff Country EZ ride springs, and a zero rate
RR = 12 bolt with 4' shackle flip, 2.5" Tuff Country EZ ride springs....the rear custom bumper weighted down this set-up, so it has roughly an even stance
350 SBC, 700R4, 203/205 doubler with triple stick All ORD components
85'
stock 10bolt FRT & RR
stock 305, 700R4, 208
I want to use any and all 69' components possible. Will they cross over or will there be any modifications needed to the 85'?
....i.e.
can I use the 69" shackle flip?
exhaust clearance? custom 69' exhaust will used if possible
crossmembers needed? can 69' x-members for tranny and tx-case cross over?
do I need to relocation of any axle/shock mounts?
triple stick position in hump? any special consideration?
is a body lift needed?
any other issues I am forgeting?
do I need any other parts for this swap?
72 Suburban Ambulance 4x4 - 350, T-400, NP205, A/C, PS, PB, 4 wheel disk, 4" lift 33" tires
diggy is offline   Reply With Quote
Thread Tools
Display Modes
