07-29-2009, 02:30 PM | #1 |
dang its hot
ball joints
the ball joints on 1/2 ton and 3/4 ton have different part numbers. What is different? Will 3/4 joints fit 1/2 ton arms? Is the difference the size of the spindle mount or is the whole joint bigger? If one were to say, make a 1/2 ton a 3/4 ton or visa versa is the joint all that needs changing or the whole arm? Anyone done this? I could go to the parts store with my measuring calipers but I'm asking first before I dive into this question.
07-29-2009, 10:41 PM | #2 |
dang its hot
Re: ball joints
anyone?
07-29-2009, 10:55 PM | #3 |
Re: ball joints
3/4 balljoint is bigger all together. the hole for the balljoints are different sizes
07-30-2009, 06:54 AM | #4 |
dang its hot
Re: ball joints
thank you!
08-01-2009, 12:26 PM | #5 |
Re: ball joints
correct, the 3/4 ton and 1 tons have the same balljoint number and the whole balljoint body is larger as well as the tapered shaft. however the control arm dimensions are the same on all those trucks. so you can swap in the arm you need for the spindle you need.
08-02-2009, 11:33 AM | #6 |
Re: ball joints
Yep, that means a different spindle for the 3/4 ton. The control arms are interchangable, but you may notice some additional reinforcement on them for 3/4 ton. That's the same for the trailing arms if you have a sprung rear.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
08-02-2009, 11:32 PM | #7 |
Re: ball joints
1/2 ton ball joints wont work on 3/4 and vise versa.. the holes in the arms are different sizes
Thread Tools | |
Display Modes | |
