Old 07-30-2009, 07:28 PM   #1
workinprogress67
looking for a 5x4.75 disc pattern
hi, i am looking for a 5x4.75 front disc bolt pattern for my 67 c10.i found a conversion kit from cpp and it says it will only work with stock spindles and i have 2.5" drop spindles. does anyone have or know of were i can find this pattern?
workinprogress67 is offline   Reply With Quote
Old 07-30-2009, 07:49 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: looking for a 5x4.75 disc pattern
We have re-drilled the 5x5 rotors to 5x4.75 and then machined the nose cone down so the smaller bore car wheel would fit over it. Any machine shop should be able to handle the job. This might be the best option.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 07-30-2009, 09:12 PM   #3
workinprogress67
Are there any conversion kits? machine shops can get pricey.also my other question is, why does cpp say the 5x4.75 kit only works with stock spindles? drop spindles only lower the hub.
answer greatly appreciated
Old 07-30-2009, 09:35 PM   #4
BarryB
BarryB's Avatar
Theres a WIW thread over in the WIW section, a member removed his 5X4.75 disc frontend out from under his truck go check it out.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 07-30-2009, 10:30 PM   #5
PBFAB.COM
PBFAB.COM's Avatar
Not sure of any conversion kits that aren't complete (spindles/rotors/calipers).
Last time we redrilled the rotors and machined the nose-cone I only spent $50. It may be worth checking into.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Thread Tools
Display Modes
