Old 08-02-2009, 03:49 PM   #1
tdave00
Restoring a 68 SWB
tdave00's Avatar
Making some Cups. Need advice!
I have to have a set of cups today and couldn't wait to have them shipped. I can't find any round pipe locally to make them out of. Can I just make them square? A cup doesn't set down into the seat perfectly anyway because the lower control arm is molded to fit the outline of the coils. So, just wondering.
Also, am I correct that the lower cups are only mounted to the bag and not to the lower control arm?
Gonna have my wife monitor this thread while I am at the garage, so please respond back with your advice. Thanks.
tdave00 is offline   Reply With Quote
Old 08-02-2009, 04:05 PM   #2
Shane
Shane's Avatar
Re: Making some Cups. Need advice!
if I didn't have round / tubing to make cups then I would just add a plate across the spring pocket and use that as opposed to using square for the cup bottom
Shane is offline   Reply With Quote
Old 08-02-2009, 06:27 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
What's the hurry?
I would wait for some round tube or wait to haved some shipped.
Actually I have seen people run no lower cup at all.
Keith
Convert to disc brakes.
Old 08-02-2009, 08:44 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
Unless you really are trying to slam the truck, just putting flat plate on the lower A-Arm should be within around 1/4" of how low you can get with the cup from what I've read. I'm either going to do that or put round tube in the lower A-arm so that the bag sits down into the arm and I can run more air in the bag when I'm driving. Not to get lower.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 08-02-2009, 10:02 PM   #5
tdave00
Restoring a 68 SWB
tdave00's Avatar
I have just a few days to get my truck rolling again and out of the garage, so I had to do something. I bought some 1 1/4" wide metal and bent it into a circle then welded 1/4" plate on top of it. The first one I made was too big (duhh moment) so I had to make some relief cuts in it and beat it back to angle into the hole. I welded the relief cuts back up and grinded them smooth. They look like they will work pretty good. They are 1 5/8 - 3/4" tall.
Old 08-02-2009, 11:30 PM   #6
bedsled71
bedsled71's Avatar
it will be fine.. ive seen waaaay worse
bedsled71 is offline   Reply With Quote
Old 08-02-2009, 11:30 PM   #7
Shane
Shane's Avatar
Those should work just fine ... Good Job!
Old 08-03-2009, 12:10 AM   #8
tdave00
Restoring a 68 SWB
tdave00's Avatar
I like your reply better than "I've seen way worse." Thanks Guys.
Old 08-03-2009, 09:30 AM   #9
justpball
justpball's Avatar
Lol ^^^
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 08-03-2009, 10:27 AM   #10
bedsled71
bedsled71's Avatar
i didnt mean it in a bad way but owell. take it how you wanna take it
Old 08-03-2009, 01:34 PM   #11
tdave00
Restoring a 68 SWB
tdave00's Avatar
It's cool. Just cutting up.
Thread Tools
Display Modes
