Old 08-07-2009, 12:59 PM   #1
dragn91
dragn91's Avatar
stock height of a rear c10 coil please help
i need to know the stock height of a rear coil spring for a 60-72 c10 mines a 66 if that matters. i purchased a set of rear chevelle coils because i heard they would drop the rear but they look much taller. it could be the weight of the truck so i need to know how tall they are out of the truck. the coils are only temp. im trying to drive the truck to a show tomorrow but i dont want it sitting stock. also if anyone has any piks of rear drop blocks they have made id appreciate it also.
dragn91 is offline   Reply With Quote
Old 08-07-2009, 01:34 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: stock height of a rear c10 coil please help
dragn91, I will get you a measurement tonight, as I have a stock rear coil I just pulled off my truck. It might have settled a little of the rears, but not by much.
That is if someone doesn't beat me to it...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-07-2009, 01:46 PM   #3
aggie91
I'm just glad to be here!
aggie91's Avatar
The unloaded length (heigth) of the coils is about the same IIRC, but look at the diameter of the wire used to make the spring. The truck spring is much larger in diameter. The Chevelle spring is a lighter weight/in spring rate and will lower the truck and give a softer ride.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-07-2009, 06:29 PM   #4
dragn91
dragn91's Avatar
thanks guys.
Old 08-07-2009, 08:58 PM   #5
bedsled71
bedsled71's Avatar
about 12 1/4 inch not installed
bedsled71 is offline   Reply With Quote
Old 08-09-2009, 03:44 PM   #6
dragn91
dragn91's Avatar
damn the chevelle springs i bought are 16 1/2 even though the metal is thinner i dont see the compressing that much. does anyone know what year people are useing to get a decent drop? these are off a 1967
Old 08-13-2009, 10:39 AM   #7
Jblackie47803
Jeep Wrangler springs. Get them at a shop that performs lifts on Jeeps. They let the stock springs go cheap. got mine for 10 bucks apiece. About an inch shorter than the truck's stockers and a lot lighter guage.
Jblackie47803 is offline   Reply With Quote
Old 08-16-2009, 11:34 PM   #8
grayharville
^^who I am^^ what I say>
grayharville's Avatar
do you have to mod anything to fit the wrangler springs? they look smaller diameter, what years work? those are off the front right? how much drop would be expected? sorry for all the questions, but i really need a cheaper way to lower my truck!
grayharville is offline   Reply With Quote
Old 08-18-2009, 09:53 AM   #9
Jblackie47803
We are talking rear springs here. The jeep springs bolted right in using the stock spring retainers (ears). This lowered the back of the truck over 4 inches. I was going to get 2 inch lowering blocks as well but decided I didn't need them after getting the springs in. This with new 205/65-15 tires slammed the back end. This pic is from a really bad angle to show the stacne but it's the only one I can get to right now...I'm at work. I'll try to post a good one taken on the garage floor later.
Old 08-18-2009, 09:54 AM   #10
Jblackie47803
Old 08-18-2009, 09:59 AM   #11
Jblackie47803
We are talking rear springs here. The jeep springs bolted right in using the stock spring retainers (ears). This lowered the back of the truck over 4 inches. I was going to get 2 inch lowering blocks as well but decided I didn't need them after getting the springs in. This with new 205/65-15 tires slammed the back end. This pic is from a really bad angle to show the stance but it's the only one I can get to right now...I'm at work. I'll try to post a good one taken on the garage floor later.
Old 08-19-2009, 10:10 AM   #12
grayharville
thanks! i would like to do this, as it seems cheapest. so what i need, is rear jeep wrangler coils springs?
what can i do up front? just cut em or what would yall suggest? im going for budget right now, just to get it down some
Old 05-04-2010, 09:53 PM   #13
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
hmm so just ask for jeep wrangler springs?...what years and I assume rear springs?..
John
1999 Toyota Tacoma 4x4
Old 05-05-2010, 08:38 AM   #14
chevykid65
chevykid65's Avatar
thats pretty neat. ill have to look into that. i always thought jeeps ran paralell leafs. been trying to figure out what to do to my trucks rear end. im also doin a bugetbuild on my 65
chevykid65 is offline   Reply With Quote
Old 05-05-2010, 09:32 AM   #15
oldblue1968chevy
how much lbs will I be able to haul without bottoming out? and you say there about a 4.5" drop?
John
Old 05-10-2010, 02:52 PM   #16
Renfro85
so im still wondering what year wrangler springs will work, cause this is the route im taking to get low
Renfro85 is offline   Reply With Quote
Old 07-16-2010, 12:02 PM   #17
leddzepp
Moderator
leddzepp's Avatar
Don't waste your time. I just put a set in the rear of my truck, and it DID NOT lower it AT ALL. I have read on here several times that you will get a 4" drop using these coils and I would like to know who has actually done it and measured it. I put the coils side by side and they were identical in height. The lighter gauge of the Wrangler coils makes for less weight rating, but even standing in the bed with another person it only went down about a 1/4"
leddzepp is offline   Reply With Quote
Old 07-16-2010, 12:23 PM   #18
blime81
Laid Lo
blime81's Avatar
You are looking for 97-06 Wrangler (often refered to as a TJ) REAR springs. The TJs use
coil springs and they get junked all the time when the jeep gets lifted.
Not sure about your problem leddzepp. Are you sure they were stock height jeep springs? The factory jeep spring itself is shorter than the OEM truck spring so you should have at least seen some drop....
Semper Fi,
Jeff
'72 C10 - lays frame
'07 Sand Rail - ecotec powered
'05 2500HD - tows stuff
'67 VW Bug - gas saver
'01 Jeep TJ - rock crawler
blime81 is offline   Reply With Quote
Old 07-16-2010, 03:01 PM   #19
leddzepp
Moderator
leddzepp's Avatar
Positive, still have the stickers on them. REAR springs from an 03 TJ Wrangler. They are slightly shorter than factory truck springs (so slight it is insignificant), a lot thinner gauge, but other than that, identical. It dropped at most 1/4", far far short of the 4" claims I read on here.
Old 07-16-2010, 05:23 PM   #20
blime81
Laid Lo
blime81's Avatar
That sucks. I know its a pretty common swap. Wonder how much they settle or if everyone else was using junk yard ones.
Semper Fi,
Jeff
Old 07-16-2010, 06:14 PM   #21
grayharville
its possible that your stock springs had settled 4 inches. lol. on the other hand, those TJ springs may have been from a Jeep Wrangler Rubicon edition, i believe those sit higher from the factory.
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
Thread Tools
Display Modes
