08-09-2009, 02:29 AM | #1 |
T-Case which one is it? LOL
A friend gave me a 72 k20 with a 700R4 and a transfercase with no markings except what was molded on the case, dont know how to maintain it let alone use it LOL how do I figure out what I got?
Here is a pic of it...Anyone rcognize it? Last edited by Timmy Berk; 08-09-2009 at 10:05 AM. Reason: More info |
08-09-2009, 02:33 AM | #2 |
People know me
Re: T-Case which one is it? LOL
more than likely a 208 or a 241
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
08-09-2009, 02:50 AM | #3 |
Are there pics somewhere to reference it visually?
08-09-2009, 10:32 AM | #4 |
Apache Club
that gear cover in the middle tells it to be a 205
here is a linky http://www.chuckschevytruckpages.com/drivetrains.html
58 CHEVY APACHE I 74 CHEVY C-10 I 78 K-10 donor truck I 89 SONOMA
My Trucks Apache Sitting Idle MySpace Project Dad's Truck (74 C-10 to K-10 conversion) Last edited by Igotachevyor2; 08-09-2009 at 10:40 AM. |
08-09-2009, 10:39 AM | #5 |
20' Daredevil (Ret)
Yup, it's a 205.
08-09-2009, 10:48 AM | #6 | |
Yup, 208s and 241s were slip-yoke style and had aluminum cases...that big hunk of iron is a 205.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
08-09-2009, 10:51 AM | #7 |
Oh man THANK YOU I went to check the fluid and it GUSHED out every where 3 miles from home last night and I didnt have a clue as to what to put back in... still dont LOL
08-09-2009, 01:22 PM | #8 |
Born Psycho
regular old 90 wt. gear oil is all it needs, BUT, if the fluid "gushed out" you might want to take a hard look at the seal between the auto trans and the t-case. i had that happen many years ago with a 350/205 combo, t-case was way overfull and transmission very low.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
08-09-2009, 02:21 PM | #9 | |
20' Daredevil (Ret)
Yes, or 75W-90... and I would use synthetic
08-09-2009, 04:02 PM | #10 |
08-09-2009, 04:12 PM | #11 |
I have another NP205 for sale in the parts section but if you need another one you can come and get this one for free. I aint' moving it ever again
08-09-2009, 04:36 PM | #12 |
Kid's Mechanic
That 205 is one tough transfer ................LOL I haven't broken mine and I know I treat mine rougher than most
If its overfull on lube the seal between the tranny and the transfer may be bad And don't jump an atv ramp with out the extra t case support brackets,The transmission housing won't be happy Last edited by powerdriver 1958; 08-11-2009 at 07:24 PM. |
08-10-2009, 08:10 PM | #13 |
205's came both ways. With or without slip yoke tailshafts.
Regarding 205 transfercase fluid, My 1972 called for 80/90 gear oil. My 1980 called for 30w motor oil. My 1988 V30 calls for ATF. They all work in a 205. Last edited by Dooley; 08-10-2009 at 08:12 PM. |
08-12-2009, 01:50 AM | #14 |
Bloodied Knuckles
I once heard it said: "you could probably jizz in a np205 a thousand times and be fine, the just like anything thick n slippery" lmao
08-12-2009, 11:29 AM | #15 |
08-14-2009, 05:29 PM | #16 | |
-Don- '66 C10 w/factory A/C '77 Cheyenne K5 350/465/205 '80 Custom Deluxe K20 350/465/205 '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf |
08-15-2009, 12:03 PM | #17 |
My rule of thumb for what fluid to use is based on the tranny. If its auto, I run ATF in the tranny and xfer. If its a manual I run gear oil in the tranny and xfer.
Thread Tools | |
Display Modes | |
