Old 08-13-2009, 03:31 AM   #1
Bowtie7ty
1 piece fiberglass front end
How much lighter are these than a steel front end? I found one in my area for $300. What do u guys think. Im going for weight reduction so is this worth it?
Bowtie7ty is offline   Reply With Quote
Old 08-13-2009, 04:49 AM   #2
Re: 1 piece fiberglass front end
I guess it would be good on a drag truck.I don`t see much use elsewhere.
Old 08-13-2009, 04:49 AM   #3
tecky11
how about some more info?
tecky11 is offline   Reply With Quote
Old 08-13-2009, 05:20 AM   #4
cdowns
cdowns's Avatar
they are usable and save some weight// you must have excellent fabrication and finishing skills for it to look and work good// they are not off the shelf bolton type of deals
Old 08-13-2009, 05:21 PM   #5
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
I used to have a friend who worked with fiberglass bodies and I can tell you it's a heck of a lot of work and usually you have to correct defects in the fiberglass surfaces to make it look right. If you have a body shop at your disposal, go for it. If you are just a garage guy like most of us I would look elsewhere for weight reduction. Just my $.02. BTW, I don't know exactly how much lighter. It depends on the amount of brackets, bracing, etc. that you end up using.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 08-13-2009, 06:20 PM   #6
mclairmo
I would stick with steel. I installed a fiberglass hood on a 66 Mustang and it was junk, did not fit perfectly, had chunks missing at the edges and was harder to prep and paint.
mclairmo is offline   Reply With Quote
Old 08-13-2009, 10:01 PM   #7
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
just a few random thoughts.
are you going to be racing the truck? track only or street driven? what are your plans for weight loss/redistribution on the ride?
if it's a street driven truck, then a 'race weight' front end won't hold up for very long. typically a race weight front end would prolly be somewhere around 50#.
my 'street weight' front end is 1/4" thick on average, and weighs about 80#-100#, maybe 120# tops. Plus the weight of the core support braces, the hinge or other mounts needed for the new front end.
you can save some decent weight by going all glass. but this would require fabbing some core support braces. the steel fenders give the core it's rigidity.
I always tell people if they want to drop weight off the front, and street drive it, then a glass hood and roll pan are a good compromise. you still have all the strength and structure for your core support/rad/batt, hood etc from the steel fenders. You'll have to stretch the spring on the stock hinges or use different hinges for the glass hood. but dropping the weight from the steel hood and bumper will save you a good bit of weight without all the hassle and headache of a 1 pc front.
a few thoughts about the front end. going for $300 is awful cheap, I'd wonder why. maybe it's race weight and they found too flimsy for street driving. just check out the front end well if you decide to go for it. It could just be a good deal waiting.
I'd like to see pics of it too..
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
radiused fiberglass fender project for 67-72
Last edited by Mordachai; 08-13-2009 at 10:03 PM. Reason: you'll prolly get better weight loss info in hi performance forum....
Mordachai is offline   Reply With Quote
Old 08-14-2009, 09:17 AM   #8
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
If it is the one that was for sale @ Goodguys it is brand new - looks just like the one in the above posting
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Thread Tools
Display Modes
