![]() Join Date: Jul 2002
Power steering pulley too far out?
I just bought a double pulley so I could run my power steering pump. It still does not stick out as far as my pump pulley. The pump pulley is at least another inch out from the double pulley. What am I doing wrong? Am I missing something to align them?
1967 Suburban, my kids call it the SuburBEAN cuz its long and green. |
its all about the +6 inches
Sounds to me like you have a long water pump and the brackets holding your steering pump are for the short bracket set up.
Grubbin'
Do you just have a two groove pulley on your crank or did you add a two groove to your existing crank pulley (making a total of 4 grooves)? Also, there are three different offsets for the pump pulley. Someone posted a pic a while back showing the three different offsets. I know it's frustrating as hell trying to locate parts and line everything up. I just went through this myself, and every corner I turned seemed to be a new surprise. Let me know what you got going and I got some pics from my 69' that might help you map it out. Wifey got a digi cam for christmas so pics are a breeze now!! Anyway, let me know.
project rust attack 1969 Chevrolet LWB w/ 307. I got power steering now woohooooo!!!!!!! Last edited by rusty ol' 69'; 01-11-2003 at 03:04 AM. |
Pulley
I had a single groove pulley and replaced it with a double groove. I will post a picture in just a few minutes. You will see how far off the ps pump pulley is. I do actually have a short water pump.
Pictures
The black pulley in the middle is the new double, Hope these help.
Grubbin'
You need to get an add on pulley
I ran into the same problem I'll try to find the link to the post I did on this earlier but in the meantime here are some pics of what mine looks like now. I got the pulley from Desert Rat and he said he has more so you should email him.
project rust attack 1969 Chevrolet LWB w/ 307. I got power steering now woohooooo!!!!!!! |
Grubbin'
A little better shot from the side
You can see the double groove pulley mounted to the crank w/ an additional double groove pulley mounted on top of that. The add on fits inside your existing pulley and the two pulleys bolt up together with longer bolts.
Grubbin'
Here's a link to help you out
http://67-72chevytrucks.com/vboard/s...threadid=32198 and one more http://67-72chevytrucks.com/vboard/s...threadid=32198 Hope that helps. Let me know
Desert Rat
I have e-mailed desert rat hoping he has another to help me out. I anyone talks to him, have him take a look at this post.
Grubbin'
Good thing I took that pic I was looking at it and noticed that my alternator belt was in the wrong groove on the crank. It should be on the one closest to the block and it's one away from the block. Whoops!! Anyway, PICKMUP also said he had one so you could try him too. Good luck.
![]() Join Date: Dec 1999
Which one do you need?the inner or the outter? i have some outer 1 rows and outter 2 row cast,inner i have some 1 row,i think i have a couple 2 rows left? email me gmcrat427@yahoo.com
Thread Tools | |
Display Modes | |
