Old 08-20-2009, 09:32 PM   #1
mas09ts
mas09ts's Avatar
Brake Swap Questions
Ok fellas i was thinking about swapping out my drums up front on my 70 GMC to discs. Ok now i've got parts off of a mid to late 70's chevy frame that I could use I think. Can I just swap the spindles and rotors and calipers and such? And as it sit the 70's frame up front is 5 lug and my truck is 6, so could I just swap the rotors to 6 lug and it bolt on to the 5 lug spindles and bolt right up to my truck. Thanks in advance guys......
Mitch
22yrs. Young
1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011
Current Project 68 Gmc "Second Chance"
Go to my 68 GMC Shorty Rebuild Thread
http://67-72chevytrucks.com/vboard/s...39#post6341739
mas09ts is offline   Reply With Quote
Old 08-20-2009, 10:13 PM   #2
mas09ts
mas09ts's Avatar
Re: Brake Swap Questions
anyone?
Mitch
22yrs. Young
Old 08-21-2009, 12:42 AM   #3
dmnall
dmnall's Avatar
Hey Mitch,
They will bolt up after you change the ball joints.. I think you will have to change the tie rod ends and possibly the pitman arm as well *but it has been a few years since I thought about this on my 68*. Then don't forget to change the proportioning valve as well. The one for the drum/drum will not work. Then since you have a 70 rear end, you can get axles for a 71 - 87 12 bolt axles and swap over to 5 lug in the rear as well..
The easiest way I recommend and I am going to do is just go get the front cradle from a 73 - 87 *front suspension disc to disc* and swap the front cradle, that way you get the newer motor mounts which is one of the plus sides..
HTH,
Charlie
1968 C10 Truck LWB Fleetside
1968 C10 Truck SWB Stepside
1994 K2500 Ext Cab Fleetside
2008 Honda Civic Si *lease*
dmnall is offline   Reply With Quote
Thread Tools
Display Modes
