Old 08-23-2009, 05:46 PM   #1
KQQL IT
At the body shop.
KQQL IT's Avatar
BBC in a 73
Ive seen a few threads with different header combos ie car headers with 2inch or bigger tubes in a 73? Can you help with pics and part numbers?? Thanks in advance.
KQQL IT is offline   Reply With Quote
Old 08-23-2009, 09:25 PM   #2
cobb
cobb's Avatar
Re: BBC in a 73
I believe the headers im running are for a 454 they are 3" collectors. They hang a little low but it works. Sorry i dont know the brand.
cobb is offline   Reply With Quote
Old 08-23-2009, 09:43 PM   #3
bigblock73
yeller
bigblock73's Avatar
Re: BBC in a 73
Sanderson BB8's...I have them in my 468 '73...fit like a GLOVE!
bigblock73 is offline   Reply With Quote
Old 08-23-2009, 11:05 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: BBC in a 73
What tube size are the bb8s? Alsoi should have said long tube 2" or bigger Thanx again
" That didnt make it any newer "
" Dont antique the equipment "
Old 08-28-2009, 11:45 PM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: BBC in a 73
Ttt
Old 08-29-2009, 04:26 PM   #6
454HO
Re: BBC in a 73
I'm curious why you need 2" or bigger. What are the specs on your engine? Must be a behemoth. Lot's of cubes and a blower maybe?
- Greg
454HO is offline   Reply With Quote
Old 08-29-2009, 04:39 PM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: BBC in a 73
2" match the ports on the heads And future plans for 498" 13:1 fire breather...
Old 08-30-2009, 06:12 PM   #8
454HO
Re: BBC in a 73
Port size and tube size are two different things. I agree it is a good thing that the header flange matches the port on the head, but that does not mean the primary tube has to have the same cross-section area. Unless you are running larger than 1.88" exhaust valves and lots of lift, a 1-7/8" primary is the max you should need. Any larger will probably hurt flow velocity.
- Greg
Old 08-31-2009, 06:21 AM   #9
AirMale
AirMale's Avatar
Re: BBC in a 73
hooker #2455 also avaiable in stainless
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 08-31-2009, 05:37 PM   #10
Moostifer
a fool with no money
Moostifer's Avatar
Re: BBC in a 73
yeah... what he said!
a well tuned exhaust is just as benificial as a well tuned carb!
if you are wanting the absulute most out of your combination, do a search for pipemax header design... it will be an educational journey
Basicly stock 83 SWB with a few Bolt-ons
before, during and still during
http://photobucket.com/albums/y251/moostifer/truck/
http://photobucket.com/albums/y251/moostifer/motor/
Moostifer is offline   Reply With Quote
Old 09-05-2009, 12:33 PM   #11
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: BBC in a 73
Maybe.. but the 454 for the 73 is in a nova that runs 11.40s with 2" tubes
Thread Tools
Display Modes
