Old 01-12-2003, 12:16 AM   #1
krazy_texan
krazy_texan's Avatar
cowl induction
i have 2 hoods for my truck how hard would it be to make one into a cowl induction my self instead of buying on or should i sell both hoods and use the money to buy a cowl hood
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 01-12-2003, 12:21 AM   #2
Mudder
Mudder's Avatar
cowl hoods cost around 400, plus paint. you can buy cowls or scoops for hoods but i think they are bad about cracking.
Mudder is offline   Reply With Quote
Old 01-15-2003, 01:24 PM   #3
smokekiki
Mike
smokekiki's Avatar
cowl hood
The speed center in rapid city SD. sells steel scoops.They are 150.00. www.thespeedcenter.net I don't know any thing about them. You have to think about the time and materials vs.the cost of new hood. Mike
smokekiki is offline   Reply With Quote
Old 01-15-2003, 01:31 PM   #4
still w.i.p '68
Dreams are free
still w.i.p '68's Avatar
I wish they had steel cowl hoods, with alittle taller scoop, maybe 4 to 6 inch options, how tall are the ones offered now 2 1/2 ?
'68 swb fleetside
originally w.i.p '68
member since 1-01
w.i.p = ( work in progress )
still w.i.p '68 is offline   Reply With Quote
Old 01-15-2003, 01:55 PM   #5
70c10
67-72 Addict!
70c10's Avatar
Don't do fiberglass on steel!. It looks good for awhile. Here's my last truck with a Harwood 2.5" scoop.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-15-2003, 02:43 PM   #6
67/72junkie
hood
If you have any welding and fabrication skills you can make your own.All of the after market cowl hoods I have seen are made off a camaro pattern. By this I mean the ridge in the hood is the same as the camaro and not the wide ridge of the truck.I took and old hood and used a sheetrock square to lay out the width ,height and mounting flanges.I cut it out with a cutoff tool so as not to distort.I then took and old pair of vise grip an welded a couple of pieces of angle iron to them to use as a hand brake to make the bends and shape the scoop.I then cut the 2nd hood so that I could slide scoop in from the bottom up to the flange I had bent on the scoop.I drilled 1/8 in holes every 2 inches along the flange and mig welded them as spot welds.Once this is done you can finish weld the scoop. I put a spot with the mig about every inch.After going all the way around I started at the first spot and repeated the process as many times as necessary until welds were continuous.After grinding and finishing it needed very , very little bondo to finish grinding marks.I did this for myself obout 6 or 7 years ago before goodmark started producing them.I was at the drag strip about 6 months after I put it on my truck and had a guy offer to purchase it.I told him it was not for sale but when he offered $500 for it I drove home without a hood.I probably had about 10hrs of fitting and welding to get it finished and primed.I have one laid out now but have not did the cutting and welding yet.I will try and work on it in the next couple of weeks and take pics as I go along to post for anyone interested.
67/72junkie is offline   Reply With Quote
Old 01-15-2003, 02:51 PM   #7
Reumster
L.E.D. Freak
Reumster's Avatar
67/72junkie you have a picture of that custom cowl hood? I wasn't aware that the center ridge was different from standard hood ridge. Is it like that with all after market cowl hoods?
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 01-15-2003, 02:51 PM   #8
70c10
67-72 Addict!
70c10's Avatar
That is the CORRECT way to do it!. Steel on Steel is the only way to go. Thanks for sharing that.
Jim
Old 01-15-2003, 03:13 PM   #9
67/72junkie
hood
I don't have any pics of the hood I sold but I will take pics of the one i'm doing now and post.It will probably be 3 weeks before I get a few nights In the shop to work on it .I have to make a trip to NV and a trip to Kansas before I do anything else.Every aftermarkethood I've seen has been a camaro pattern but that doesn't mean there isn't one with the wide ridge.I just haven't seen one personally.I made mine about 3 1/2 inches high and slightly longer than the camaro style so that it starts more towards the front of the hood .I think the camaro style is a little small for our hoods.
Old 01-15-2003, 03:23 PM   #10
67/72junkie
hood
If you look at the hood in Big Os Post Char pics you will see what I'm talking about.The hood on that truck has the narrow ridge but is a newer style that the scoop goes all the way to the leading edge of the hood.
Thread Tools
Display Modes
