Old 08-24-2009, 07:52 PM   #1
sparkyhunt
box or plate for shortened frame
I just shortened my frame using the step method and was wondering if I should weld a plate to the backside or if I should box the frame in? Also what size metal for the plate or box? Thanks
sparkyhunt is offline   Reply With Quote
Old 08-24-2009, 08:17 PM   #2
bedsled71
bedsled71's Avatar
Re: box or plate for shortened frame
either should work ... use 1/8 or 3/16
bedsled71 is offline   Reply With Quote
Old 08-24-2009, 09:24 PM   #3
Ronm909
67GMC Slammed
Ronm909's Avatar
dont buy the CPP frame stiffener, it is made just for that but it did not fit and then to try to get any help from those guys is imposible
Ronm909 is offline   Reply With Quote
Old 08-24-2009, 09:27 PM   #4
SCOTI
SCOTI's Avatar
I got some from ECE & they fit. I did this conversion & used 3/16" for fish plate & boxing.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-24-2009, 09:48 PM   #5
ghettoluxury
ghettoluxury's Avatar
3/16 and just plating is fine unless you want a fully boxed frame
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 08-25-2009, 10:41 AM   #6
newagecustom
c10 Chop Artist
newagecustom's Avatar
Its stronger to fish plate the directly over the joint than to box the frame. If the weld cracks the crack will run into the plate and stop instead of continuing all the way through. Here is a pic of a 66 frame i shortened to a SB wheelbase.
newagecustom is offline   Reply With Quote
Old 08-25-2009, 05:59 PM   #7
sparkyhunt
3/16th plate it is. thanks for the input.
Old 08-25-2009, 07:59 PM   #8
p8ntballer1911
Bodydropped71
p8ntballer1911's Avatar
Doing both would be fine to!
p8ntballer1911 is offline   Reply With Quote
Thread Tools
Display Modes
