Old 08-25-2009, 12:41 AM   #1
jess66chevy
jess66chevy's Avatar
Aluminum vs. standard trans cooler
Is anyone using a trans cooler like this one? Are these any better than the standard ones ?
jess66chevy is offline   Reply With Quote
Old 08-25-2009, 07:24 PM   #2
kizer
Its Deja Vu time again
kizer's Avatar
Re: Aluminum vs. standard trans cooler
From my attempting to weld on Aluminum it will transfer heat to the entire object opposed to steal which will let you heat up one spot. Finally got the spot to heat up and weld then all of the sudden, puddle. hahahahaha
I'm guessing Alluminum transfers heat better and probably costs more, but I guess its the matter of is it worth it or not?
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 08-26-2009, 12:42 AM   #3
Captainfab
60-66 Nut
It's kinda hard to tell fropm the small pic, but that looks like a frame mount oil cooler. Is that correct? And what do you mean by 'better than a standard one'? Are you referring to the factory style that are in the radiator tank?
Old 08-26-2009, 12:50 AM   #4
jess66chevy
Yea, its a frame mounting cooler. What I mean is does the aluminum cooler cool better than the standard cooler? Heres a better pic.
Old 08-26-2009, 01:04 AM   #5
Captainfab
60-66 Nut
It depends on what you're doing with your truck. The standard front mounted cooler will do a better job of cooling the oil. The frame mounted ones are more for vehicles that don't generate a lot of heat in the transmission. BTW most trans coolers are constructed of aluminum whether they are a frame mount or a front mount.
Old 08-26-2009, 01:30 AM   #6
jess66chevy
I dont see myself using my truck for any type of towing. Just drive it like I stole it type driving. LOL. I've heard though that too much cooling will effect the shifts.
Old 08-26-2009, 01:40 AM   #7
hewlett2002000
hewlett2002000's Avatar
ive seen first hand that not enough cooling will effect shifts also. as in it wont shift anymore..... lol
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 08-26-2009, 11:44 AM   #8
MacAttack
283 Drama Queen
MacAttack's Avatar
I've had both and each has its advantages and disadvantages.
The standard in-front-of-the radiator unit is very secure and is easily installed - downside: got to keep it clean and/or it decreases the cooling efficiency of your radiator in the area it covers.
The frame mounted unit has a huge amount of over-all cooling area and doesn't restrict the coolant radiator - downside: harder to install, you've got to shield it somehow from stuff that gets kicked up off the highway, and sucks at cooling when the vehicle's not moving.
(oh, and the frame unit can leak your juice out on the road and you'll never know until your tranny dies a horrible death. If the standard one leaks the fluid will more-than-likely hit an exhaust component and smoke profusely.)
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 08-26-2009, 12:24 PM   #9
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Aluminum vs. standard trans cooler
How is your Trans built?
The Stall?
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Thread Tools
Display Modes
