08-26-2009, 12:41 AM | #1 |
transmission identification
Is it possible to identify what transmission is in my 87 by the VIN number? I tried to find a VIN identifier online but none were very helpful with the tranny.
It is a 3 speed manual in an 87 with 4wd and a 350 if anyone has a guess at what it may be. |
08-26-2009, 12:49 AM | #2 |
6.0 powered square
Re: transmission identification
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
08-26-2009, 06:48 AM | #3 |
Should be a SM465 by the sounds of it...
08-26-2009, 09:01 AM | #4 |
One shot, one kill.
I'm with prong, it's a rock crusher 465. Some had a shift patern that said 1-2-3-4 and later were marked, L-2-3-4. It's the same trans, all they changed was the knob.jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose. |
08-26-2009, 09:02 AM | #5 |
Still plays with trucks
Are you sure it's a 3-speed manual and not a 4-speed with a granny low? The shifter on my SM465 says L-1-2-3 so I can see how that could be confusing.
The only 3-speed manual I know of is the old Saginaw one from the late 60's & early 70's cars and I thought they quit using it long before the 80's. |
08-26-2009, 09:26 AM | #6 |
If it's manual and its a big long stick, its an SM465.
1982 K10 SWB 1987 V20 - Sold - Doh! |
08-26-2009, 11:38 AM | #7 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-26-2009 at 11:42 AM. |
08-26-2009, 11:39 AM | #8 |
...and "ditto" again...
If you can take a pic (either from underneath or maybe from in the cab with the shift boot removed) I'm sure somebody here can identify it. You can tell if it's a SM465 from a mile away. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-26-2009 at 11:41 AM. |
08-26-2009, 12:01 PM | #9 |
I forgot about the three on the tree. Those sucked to drive. Mine always bound up half way between first & second.
08-26-2009, 03:27 PM | #10 |
it has the L and then 1 2 and 3. here is the best pic i have of it right now.
08-26-2009, 03:39 PM | #11 |
The pic is perfect. That's the SM465 with the "granny" low gear (what I call the M20 trans).
K PS - more trivia: I am reminded that those were available with either a chrome or a black stick, FWIW...
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-26-2009 at 03:41 PM. |
08-26-2009, 04:08 PM | #12 |
Same one I have. Very tough and reliable.
08-26-2009, 08:41 PM | #13 |
Chrome stick baby!
08-26-2009, 08:46 PM | #14 |
Wait is that an automatic column shift??? Manual conversion?
08-27-2009, 10:18 AM | #15 |
Or like my old 81, a manual trans truck with a better column snagged out of an automatic truck.
08-27-2009, 11:46 AM | #16 |
08-27-2009, 12:21 PM | #17 |
So you couldn't get a tilt column on a manual truck?
08-27-2009, 12:24 PM | #18 |
To this day, and I am older, I have never heard one of the granny low 4 speeds refered to as a three speed! That is like calling a 700R4 a three speed overdrive transmission right?
08-27-2009, 12:38 PM | #19 |
My 78 has tilt and the SM465 stock.
I couldn't find a decent manual trans column for my old 81 so I ended up with a column shift auto trans column in there. I pulled the shift lever off right away by knocking out the roll pin holding it in and eventually ground off the boss and filled the void left so it looked like a manual trans column. You have to secure the shifter sleeve in place in the park position as it can rotate while you are driving and keep you from turning the ignition lock far enough to get the key out. |
08-28-2009, 12:09 AM | #20 |
No... when you drive down the road you only use 3 gears.... creeper gear never comes into play, so i call it a 3 on the floor.... becuase anyone watching you drive it would think that.
08-28-2009, 11:12 AM | #21 | |
Just because you don't use the gear doesn't mean the transmission doesn't have it. The SM465 is a four speed with a granny low first gear not a true three speed manual transmission like the Saginaw that has no granny low. |
08-28-2009, 07:23 PM | #22 |
It has 4 forward gears, so it is no doubt a 4-speed, but when non-old truck people ask about the tranny, I tell them its a 3 on the floor.
08-28-2009, 08:39 PM | #23 |
Badass
ahahah has 3 gear shifters and 3 pedels lmao
that would be fun to drive
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
Thread Tools | |
Display Modes | |
