Old 08-28-2009, 02:18 PM   #1
Tim240Z
Tim240Z's Avatar
Rear track and control arm bushing question
Are the bushings (urethane) for the rear trailing arm and track (panhard) bar the same between the 3/4 ton and 1/2 trucks/suburban (67-72)?
I need to replace the bushings in my 72 burb, but am having problems tracking part numbers.
Thanks,
1972 Suburban C20
454/TH700R4, eaton-corporate 4.10 (looking for 3.7)
Sold: 71 Cheyenne 20
Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005)
Tim240Z is offline   Reply With Quote
Old 08-28-2009, 03:04 PM   #2
SCOTI
SCOTI's Avatar
Re: Rear track and control arm bushing question
They should be the same. The difference in the arms themselves was the addition of plating on the top & bottom to reinforce them.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-28-2009, 03:25 PM   #3
Tim240Z
Tim240Z's Avatar
Thanks!
I figured as much for the control arms, but wasn't 100% sure.
As for the track bar, I seem to remember years ago, when I replaced the track bar bushings on my 71 C20 truck, that I had problems with the size....may be false memory though....
1972 Suburban C20
Old 08-28-2009, 04:28 PM   #4
Tim240Z
Tim240Z's Avatar
Well, I pulled the bar out and measured....the 3/4 ton track bar bushings are larger OD than the 1/2 ton ones. The 3/4 ton bushings are 1 3/8" OD, the 1/2 ton version is about 1 1/2".....so now I need to track down the correct part number....
1972 Suburban C20
Thread Tools
Display Modes
