Old 01-12-2003, 09:06 PM   #1
matt_field
matt_field's Avatar
mounting alternator brackets with fuelie heads?
i have 461 camel back heads, and a edelbrock performer intake manifold. how would i mount up for my alternator? whats correct for it. i was thinking come off the intake but my brackets arent right. and then off the water pump would be kinda funny? not sure anyone ?? i need help!! haha thanks
matt
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 01-12-2003, 09:16 PM   #2
bigjimzlll
bigjimzlll's Avatar
http://www.alangrovecomponents.com/
this is what im using...very very nice
Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 01-12-2003, 10:09 PM   #3
kaycee
kaycee's Avatar
EASY
Go to Checkers or whoever and they should have a bracket for this setup.The mount goes on the exh. manifold first 2 bolts and holds the bottom of the alt. like $10. Then there is the 1 that goes on top it is a long bent 1 that has the adj. hole in it that mount's to the front top bolt of the water pump.I had this exact same setup (461,Performer ) drvs side alt or is yours on the pass. side?
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 01-12-2003, 10:30 PM   #4
67/72junkie
alt
If you have factory maniolds you can get a GM bracket that bolts to the manifold.Most parts stores will have a bracket that is for use with headers but can also be used with manifolds.There are also several aftermarket low mount brackets that bolt to the block and work well in performance applications.
67/72junkie is offline   Reply With Quote
Old 01-12-2003, 10:47 PM   #5
matt_field
matt_field's Avatar
its going on the drivers side, and i have the ram horn ones with the bolt holes for the bracket
1967 swb 2wd 427bbc
1968 4wd shortbox
Thread Tools
Display Modes
