Old 09-02-2009, 09:20 PM   #1
Number21
Number21's Avatar
Cab/door interchangeability?
I'm still not sure whether or not I want to fix or replace the rusty cab and doors on my '79. Amazingly the fenders and bedsides are completely rust free even though the cab can almost be powered flintstone style.
Anyway, can anyone tell me what doors will fit on a '79 or earlier cab? Did they ever change the opening/hinges/latches? Can I get some off a newer suburban? (local yard has a ton of them)
Number21 is offline   Reply With Quote
Old 09-02-2009, 09:23 PM   #2
jrsmith_2010
I like turtles...
jrsmith_2010's Avatar
Re: Cab/door interchangeability?
im pretty sure they are all the same for the 73-87 modles, someone correct me if im wrong, if not they should just bolt on
jrsmith_2010 is offline   Reply With Quote
Old 09-02-2009, 09:32 PM   #3
3r!c84
Badass
3r!c84's Avatar
all the same
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-02-2009, 09:34 PM   #4
flamingbig10
6.0 powered square
flamingbig10's Avatar
the only changes are 73-76 doors aren't made for power window or locks, 77-87 (88-91r/v) are almost the same except the door panels and inside door handles changed in 81
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 09-02-2009, 09:43 PM   #5
Number21
Number21's Avatar
SWEET! I opened the door on one of the burbs and was just speachless about how nice and easy and quiet it opened and closed. Too bad some idiot ruined the engine in it and wrote "clunker" on the outside.
Old 09-03-2009, 06:06 AM   #6
Number21
Number21's Avatar
Alright, while we're talking about it - how do the doors come off, hinges and all? Looks like 3-4 bolts in each hinge on the body, is that it?
Old 09-03-2009, 11:14 AM   #7
elwoods76
Just Cruizin
elwoods76's Avatar
If the hinges are in good shape and quiet on the new doors, your best bet is to pull the doors off with the hinges. If they are power doors take the time to undo the wiring harness and all of the wires before you start loosening the bolts. Yes there are 2 hinges per door and either 3 or 4 bolts per hinge(can't remember sitting at my work desk).
elwoods76 is offline   Reply With Quote
Thread Tools
Display Modes
