Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 09-03-2009, 07:40 PM   #1
Skirkpat
Skirkpat's Avatar
250 L6 Pwr steering pump/brkts. and Air Cond.
250 L6 power steering pump with brackets, A/C brackets, full set of pulleys bolts and pwr. steering hoses. I am pretty sure the pump works, but am selling as-is, Came off of a 1975 Nova
125.00 plus shipping.
1969 Short Stepside
1969 4 WD Suburban
1970 1 Ton Dually....Misfit
oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door
Skirkpat is offline   Reply With Quote
Old 10-01-2009, 05:06 PM   #2
jagvic
Re: 250 L6 Pwr steering pump/brkts. and Air Cond.
Hi - I see the pulleys but they are 2 groove. How do the belts run? I have the ps and alternator on a 75 Omega now and they each use their own belt - how does the AC run???
jagvic is offline   Reply With Quote
Old 10-01-2009, 05:37 PM   #3
Skirkpat
Skirkpat's Avatar
There are three grooves, the Harmonic balancer pulley has two grooves, and the thin one groove pulley sits on on top of that.
1969 Short Stepside
1969 4 WD Suburban
Old 10-01-2009, 06:08 PM   #4
jagvic
Ah - so that gives the balancer a 3rd groove for the AC belt. Does the water pump pulley have 3 grooves also? Or does the AC belt only go around the balancer and the compressor? Thanks for your help!
Old 10-01-2009, 06:28 PM   #5
Skirkpat
Skirkpat's Avatar
I was thinking about a small block with my previous post, this should explain it a little better pic = 1,000 words
1969 Short Stepside
1969 4 WD Suburban
Old 10-01-2009, 06:50 PM   #6
jagvic
Hmmm... interesting - on my non-ac setup the groove you show for the AC belt is used for the PS... I wonder how they moved the PS forward to use the added on pulleys? But otherwise i see that the AC belt must go around the second groove in the water pump, second in the balancer and then the compressor? And that the water pump pulley is actually two pulleys.. ?
Old 10-06-2009, 01:25 PM   #7
jagvic
Is there a number visible on the add-on water pump pulley? Thanks!
Old 10-07-2009, 10:17 AM   #8
Skirkpat
Skirkpat's Avatar
I will try to check on that, I will have to find them in storage....PM me in a day or so if I do not get back to you.
1969 Short Stepside
1969 4 WD Suburban
Old 10-11-2009, 02:22 AM   #9
jagvic
Hi - did you get a chance to look for the number on that pulley??? Thanks!
Old 11-02-2009, 02:11 PM   #10
NC67Chev
NC67Chev's Avatar
Hi,
Can you tell me if the 250 I6 motor that the power steering came off of had an integrated or non-integrated head? If it came off of a non-integrated head, I would be interested in the power steering set-up and the power steering pulley.
Thanks, Mike
NC67Chev is offline   Reply With Quote
Old 03-06-2010, 07:36 PM   #11
jagvic
Do you still have this setup? I am having a tough time finding the right parts to get my p/s pump to line up with teh add-on pulley... Thanks!!
Thread Tools
Display Modes
