Old 09-05-2009, 11:51 PM   #1
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
Lift block question
I have a 68 chevy 4X4 and the rear leaf springs measure 3 inches wide, it is safe to use a 4 inch lift block that is 2.5 inches wide?
Jason
jay_shy is offline   Reply With Quote
Old 09-06-2009, 12:43 AM   #2
OrrieG
OrrieG's Avatar
Re: Lift block question
Drove mine for 13 years with 4" Rancho lift kit on the back with no problems. Kept it and plan on driving it for 20+ more!
OrrieG is offline   Reply With Quote
Old 09-06-2009, 08:02 AM   #3
I guess it could be alright.But,blocks are cheap,if you can find 3" wide.Is that the problem?How about finding some thick wall pipe to sleeve the u-bolt along the block and between the springs and bottom plate.Do you follow me?
Old 09-06-2009, 08:58 AM   #4
Mudder
Mudder's Avatar
Make sure you tighten the ubolts several times after the install. Centered that is only a 1/4 difference on each side. I ran 4" rear blocks in the rear for about 20+ yrs and never had a problem. With the blocks and stock springs the truck rode better, than with the high dollar BDS rear springs.
Mudder is offline   Reply With Quote
Old 09-06-2009, 11:47 AM   #5
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
I already have the 2.5 inch wide blocks but the 3 inch wide are readily available. Its going to bea street machine and not see offroad.
Jason
Old 09-11-2009, 01:03 PM   #6
nvrsatisfied
nvrsatisfied's Avatar
you will be fine........
like stated above check and tighten U bolts after a little bit of trip on them. check or then replace the "guide stud or bolt" make sure the "guide bolt" goes threw the springs and then tighten with a nut, which will then fit into the block to help keep it all in place.
Lug Nuts Classic Rides. (Bodywork, small fab, and Restorations)
Perry, Ok.
We're just two guys, trying our best.
72 cheyenne super
https://67-72chevytrucks.com/vboard/...d.php?t=811512
55 chevy truck
http://67-72chevytrucks.com/vboard/s...d.php?t=840174
nvrsatisfied is offline   Reply With Quote
Old 09-11-2009, 08:31 PM   #7
morgan71
I would say that your springs are 2.5 wide where they bolt to the axle. On my 68 k20 they where 2.5 in the center of the spring and 3 inches at both ends. I had them re arched at a spring shop and they told me that they where like that because the springs got wider at the ends as they rolled it out from the center going each direction.
morgan71 is offline   Reply With Quote
Thread Tools
Display Modes
