09-11-2009, 11:41 AM | #1 |
67cheby
what will pancaking the crossmember gain me
I cant afford a dropmember right now, but considering pancaking my crossmember, how much do i take out, and what else does this cause issues with, what will it gain me , is it worth it ?? I have strong arms with bags, i have raised my bed floor about 5 inches and i am step notching it right now as much as i can to fit under the bed floor, currently running a 29.1 inch front tire, how low will this get me if i pancake it
http://67-72chevytrucks.com/vboard/s...d.php?t=554172 Last edited by 67cheby; 09-11-2009 at 11:44 AM. |
09-11-2009, 12:07 PM | #2 |
Re: what will pancaking the crossmember gain me
There are a few threads on here that take you through the process. I think the most common thing I've seen is interference with the upper A-arm and steering shaft. Depending on the width of tires/wheels, you might have to trim the outer fender and mod or toss the inner.
09-11-2009, 12:31 PM | #3 |
67cheby
i forgot to add i have the new cpp modular drop spindles i think they are 2.5 inch
09-11-2009, 02:38 PM | #4 |
Steering interference requires switching to u-joints/shafts. Crossmember requires possible clearancing depending on the combination of parts. Without raising your steering box, pitman, & idler, you'll max out @ 1.5" additional drop/clearance. If you adjust the box,. you can yield more w/some other mods to the frame.
09-11-2009, 03:24 PM | #5 |
67cheby
Scoti, do you still have yours available and did you finish welding it up ?? and is it any cheaper, help a poor broke dude out with a lowering addiction !!
09-11-2009, 05:34 PM | #6 |
It's been finished (& was even installed in my 68). I indicated the pics I had available @ that time were from before it was 100% welded up. I just didn't have any available from after it was all welded (but not installed).
09-11-2009, 05:43 PM | #7 |
67cheby
how much ? do you have any pics of what you did to your steering with it in, do you have any pics of the engine compartment with it in, i am runnin my factory ac, and using porterbuilts new hood hinges (when he gets them done i already have a set paid for , i am tubing my front inner fenders into the stock inner fenders, trying to keep the engine compartment looking as stock as possible, that is the look i like, anyway i think i am interested again in doing mine or buying one if it was cheap enough, Thanks
09-11-2009, 06:17 PM | #8 |
Redefining LowBudget
I cupped my stock LCA 2.75" and I can just about lay Xmemeber without drop spindles and I can turn from stop to stop....29.5" tall ( 235/75/15 on ralleys) I f I had drop spindles on it I would be into the inner fender support then the heater box
09-11-2009, 06:39 PM | #9 |
Superbad
I bought a engine crossmember to section, but I decided to "Z" the frame instead because sectioning the crossmember will throw the steering geometry off some though out the suspension cycle.
09-11-2009, 06:51 PM | #10 |
I don't have 'recent' pics of it completely welded. These are the ones I have posted of it installed.....
http://67-72chevytrucks.com/vboard/s...59#post3475159 I would agree w/Primer70 if you decide to DIY.... If you know how to weld or can get a buddy to do it for free, a frame Z is the better option when considering steering geometry.
09-11-2009, 09:50 PM | #11 |
Does anyone use the search button anymore?
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
09-12-2009, 12:05 AM | #12 |
Have you? It works ok for some things; not so ok for others.
09-12-2009, 08:24 AM | #13 |
Search first ask questions later. I don't water down the board so that there are 200 threads to read when there could be 5.
Every forum I am on I search and find 99% of the answers to my questions.
09-12-2009, 09:02 AM | #14 |
67cheby
For your information 83 i searched several times kept coming up with the same things so i wanted some more information, if that is ok with you, maybe i should start asking you before i post anything !!!
09-12-2009, 09:04 AM | #15 |
Ok. Do me a favor & search for this info & put up the links you feel will answer the question.
09-12-2009, 09:05 AM | #16 |
i dont mind you asked before you searched, i haven't done this but enjoyed hearing the input of all those that have and i wasn't planning on searching for it, so keep the questions coming!
09-12-2009, 11:09 AM | #17 | |
You have to add a little water to make a good soup right? |
09-12-2009, 11:13 AM | #18 |
low n' slo
agree. last time i looked into sectioning a crossmember, i never seen scoti's pics. now i have..
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
09-12-2009, 12:02 PM | #19 |
Part of the issue w/the search feature in this instance is the verbage. Modifying a crossmember is called many different things: sectioning, notching, pancaking, chopping, hacking, slicing, raising, modifying. . ...
Earlier, I tried to search for the link I posted above using the board search feature (I googled the 67-72 site). It was my own post, I remember posting the info here, but it still took more than 8 pages of looking through various 'crossmember' topic related threads/posts. I wound up going back through several pages of my own 'subscribed' threads before finding it. Now, take someone that doesn't know exactly what they're seeking & it can be a frustrating task trying to find specific information.
09-12-2009, 01:03 PM | #20 |
Happy to be here
The least you could have done was impressed us with your amazing search skills by offering a couple of valid links....
Combine everything that Scoti said along with a search feature that's not working well, and it's not easy getting results these days.
09-12-2009, 01:09 PM | #21 |
67cheby
Thank You guys, i really had searched it several times i appreciate the back up!!
09-12-2009, 01:19 PM | #22 |
Seņor Member
Search 101: Don't use the google engine search box. Use the board search. To get hits in the google engine, you have to have been properly crawled, which doesn't happen very often... and you have to use search terms that google's proprietary algorithm likes.
BTW, I just used the board search for "pancake" (that's the PB, "crossmember" is too common a search word, so it gets ignored). In hits 1, 2, and 3 of the list, I got lots of info on sectioning crossmembers (one was this thread, so it could be argued that there were only 2). a) Use search (creatively, 3 or 4 times, not just once) b) use eyes and brain to read subjects on a few pages of the forum before tossing out question c) lurk a while to see if your question is a common one such that threads pop to the top a lot d) ask in new thread
09-12-2009, 01:23 PM | #23 |
67cheby
thanks for the info i had always used the google one !!!
09-12-2009, 02:07 PM | #24 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-12-2009 at 02:08 PM. |
09-12-2009, 02:21 PM | #25 |
It'd be alot cooler if you did
OK, enough about the search.
You can raise the crossmember 1.5" and have zero adverse effects on the steering. The upper a arm clearance is easily fixed with the Flaming River joints and shaft (I literally built mine in 30 minutes). Raise the steering the same amount as you do the crossmember and you will be home free. Or figure out the correct rack and pinion to use. |
Thread Tools | |
Display Modes | |
