Old 09-12-2009, 07:00 PM   #1
blizzardwarrior7
In need of some axles
Im looking for some axles for my 1967 k10....What type of axle should I be looking for, and where can I buy them?
blizzardwarrior7 is offline   Reply With Quote
Old 09-12-2009, 09:35 PM   #2
BCOWANWHEELS
Re: In need of some axles
I,d buy a dana 60 front and a 14 bolt rear out of a 1 ton chevy army truck called m1008
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-12-2009, 09:38 PM   #3
blizzardwarrior7
Will these two axles line right up with the current leaf springs? How do I know what width to be looking for?
Old 09-12-2009, 10:31 PM   #4
BCOWANWHEELS
YEP ITS A DIRECT BOLT IN. TRY GOVERNMENT LIQUDATION AUCTION SITE. THATS THE BEST PLACE TO BUY THEM. ALSO IF YOU GET A WHOLE TRUCK YOU CAN SWAP EVERYTHING FROM 1 TON SPRINGS, WHEELS, TIRES,DRIVESHAFTS TH400 TURBO WITH NP208 T-CASE ETC
http://www.govliquidation.com/
Old 09-12-2009, 11:47 PM   #5
bigbadchev72
People know me
bigbadchev72's Avatar
What are you planning on doing with it?
I got some 1/2ton axles out of a late 70s chevy with discs up front and open knuckles, If your not gonna be wheeling with it, then the 1ton stuff is a little overkill and a military truck will have 4.56 gears in it. If you are gonna run under a 35" tire that will be a little too much gear. I got 36" tires on my 67' and 3.73 gear ratio that works out nice for street use.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 09-13-2009, 01:29 AM   #6
blizzardwarrior7
Im not gonna be doing any wheeling with it, Im just looking for some replacements as the current ones are pretty rusted. So any of the dana 60s will fit the front? IT seems that some of them must be wider, because the dana 60 on my f250 is way wider than would ever fit under the chevy.
Old 09-13-2009, 03:23 PM   #7
bigbadchev72
People know me
What size tires are you gonna be running? any chevy truck 67-87 and up to 91 on the blazers and suburbans will bolt right in for the front axle, I believe in the 80s some of the front disc brake calipers use the 10mm brake hose banjo bolt.
The front axles are wider from the factory on purpose so that they track better, and aids in offroad/snow conditions, so that it can get a better bite.
Also your steering box will need to be replaced with a newer steering box for the steering to work correctly, then you will have power steering as well if you dont already. You will need a chevy or gmc front end for it to fit correctly and dodges are a 1/4" wider so the springs need to be forced apart to work. Fords will have the front differential on the drivers side, chevys and dodges are passenger side.
You would have to buy a 69-72 rear end for the perches to line up in the rear, or a 1 ton rear end out of the 73-91 chevy trucks to bolt right in. I have relocated the perches on a dozen or so axles and it is not difficult with a grinder, welder, and a little common sense.
Also if you are 1/2 ton now, you will need to buy new wheels if you upgrade to 3/4 or 1 ton axles since they are 8 lug. If you need any more info i would be glad to help. It sounds like alot more work than it really is.
Old 09-15-2009, 11:46 PM   #8
1969K10
1969K10's Avatar
So what's actually wrong with your axles? They all rust, a grinder and paint will fix that. I can understand if you want to convert to disc front brakes, but you're talking a lot of work for some rusty axles. A D44 disc is a direct swap, plus brake changes.
A D60 & 14bolt will require considerably more work.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 09-16-2009, 01:23 AM   #9
blizzardwarrior7
The gears are all but shot, the rust is substantial, enough that grinding it off would require removal of a substantial amount of metal to get them to look perfect. I would like co convert to disk brakes, and open knuckles as well. And I would also like to move to 4.56 gears.
Thread Tools
Display Modes
