Old 09-14-2009, 01:27 PM   #1
slepysal
slepysal's Avatar
Rear bumper gravel shield
So how do these install ? any one have any installed pics ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 09-14-2009, 02:23 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Rear bumper gravel shield
If they're going on a stepside I can provide some pics. Not familiar with the fleetside setup.
Old 09-14-2009, 03:12 PM   #3
slepysal
slepysal's Avatar
That would be cool thanks
Old 09-14-2009, 03:22 PM   #4
jason65
Registerd User
jason65's Avatar
4Dranch has some. I think they just bolt to the top of your brackets. The lip goes toward your bed and points up. I think he has some pics in his build thread.
jason65 is offline   Reply With Quote
Old 09-14-2009, 04:01 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Here's some pics of mine. The 1st 3 are the drivers side, 2nd 3 are passenger side. I'm not sure how they worked from the factory, I couldn't find anything showing how to install. So I attached the upper forward lip to the cross brace below the tailgate with 3 small screws on each side. The main attachment is to L brackets I bolted to the bumper brackets. I used slotted holes on the bumper brackets so I could adjust them to fit flush against the pans. It would probably look better with carriage bolts, but I had some SS bolts available so I used them instead. The rear edge of the pans do not touch the bumper.
Old 09-14-2009, 04:05 PM   #6
4dranch
Shloooooong bed member #2
4dranch's Avatar
Each bumper bracket has a mounting hole for the sheild (2 Bolts Per Side)
The sheild it self has about a (1/4" to 1/16") not sure, lip that rest on top of the bumper. Hope this helps. (This is a fleetside..)
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 09-14-2009, 04:50 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
One last note - my truck came with a Barden bumper. When I purchased the regular bumper about 10 years ago, I could not find any original bumper brackets. The originals are made of folded heavy sheetmetal like the ones pictured above for the fleetside. The one's shown on my truck are reproductions bent from steel strap. The original style may have some provision for mounting the pans.
Old 09-14-2009, 06:25 PM   #8
slepysal
slepysal's Avatar
Very cool thanks !!
Old 06-17-2010, 07:10 PM   #9
Notch1988
Notch1988's Avatar
Thanks for the pictures 4dranch. I just bought a rear bumper kit for my truck cuz it didn`t have one and I had no idea how the brackets went. Did a search and here we are!
Notch1988 is offline   Reply With Quote
Old 06-18-2010, 12:52 AM   #10
LILRED66
LILRED66's Avatar
Here are a few fleetside examples.
LILRED66 is offline   Reply With Quote
Old 06-18-2010, 06:23 AM   #11
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I replicated them for my 63 fleetside. They are easy to make if you have a brake. The circular recessed section around the carridge bolt, was created using a socket on top and a piece of pipe on the bottom in an arbor press.
Old 02-23-2015, 09:09 AM   #12
Paul Y
Dragged this one up from the bowls of the Interweb.....
Mr. Aerotruk, what gauge metal did you use out of interest and could you share a picture or two?
Looking to replicate and need a few ideas.
P.
Paul Y is offline   Reply With Quote
Thread Tools
Display Modes
