Old 01-14-2003, 12:51 PM   #1
lotik
drag it like you stole it
electric choke carb?
i ordered a edelbrock performer 600cfm carb w/maunal choke, but i received one with an electric choke. the thing is i know the electric cost a bit more, so i am thinking about using it. but how does an electric carb hook up. only think i have ever used is manual choke. can someone help or should i send it back for the manual?
negative camber //LA\\
lotik is offline   Reply With Quote
Old 01-14-2003, 12:57 PM   #2
cacauba
STL-KKN
cacauba's Avatar
I know someone will correct me if i'm wrong. But from my understanding there is a connector on the choke that you connect to ignition power, so that power is running to it only with the key in the run position. some one please confirm this, as this will be my next upgrade after the new motor.
1969 C10 350/POWERGLIDE
1991 1500 EXTCAB 350
Formally: collegeK5er
cacauba is offline   Reply With Quote
Old 01-14-2003, 01:09 PM   #3
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
You need to run 12 v to the contact on the electric choke , I ran mine to the unfused vacent contact on the fuse box , make sure you only have 12v when the ignition key is turned on .I used 12 gauge wire and installed a 5 amp inline fuse just for protection .
FYI if you ordered a 1405 there is a difference in the Metering rods and jetting ,from the 1406 .
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 01-14-2003, 01:10 PM   #4
lotik
i'm pretty sure mine is a 1406 but i'd have to go look to be positive. what do metering rods have to do with?
Old 01-14-2003, 01:29 PM   #5
Mixup
The 1406 is 2% leaner than the 1405. The 1406 is the electric chock model. The 1406 has .098 primary jets, .095 secondary jets and .075x47 metering rods. The 1405 has 100 primary jets and .095 secondary jets with .070x47 metering rods.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 01-14-2003, 01:52 PM   #6
lotik
that doesn't have any meaning to me.. heh over my head i guess
Old 01-14-2003, 01:53 PM   #7
lotik
back to the topic... so that is all you have tyo do to hook up an electric carb is run a power wire to it from a source that has power when the key is in th on position? seems pretty easy.
Old 01-14-2003, 03:28 PM   #8
Mixup
There is also a ground wire on it.
1969 Z28 engine
Turbo 350
Old 01-14-2003, 07:34 PM   #9
Bill72BB
Bill72BB's Avatar
lotik
That is all you need to do to make the electric choke work,the ground strap is only about 4" and it is usually already on the choke cover screws .If you are replacing a Q-jet with the Edelbrock you will need a adapter plate ( Spread bore to square bore ,about 19 bucks at Kragen ).
You might need to move the throttle linkage bracket back about 1 "or 2 to get full throttle,Edelbrock sells a adapter , I made one out of some stock bought at Lowe's cost about 4 bucks and took 5 min to cut off 2" .
The # of the Carb you have is stamped by the front left mounting bolt hole .
the 1405 is more of a performance carb than the 1406 which will give you better milage .
BILL
Member DUF Club
Old 01-15-2003, 11:58 AM   #10
Bob Chayer
I ran the hot wire on all of my electric choke carbs from the + side of the coil. Works well.
Bob Chayer
71 3/4 ton 4X4 Suburban
Bob Chayer is offline   Reply With Quote
Old 01-15-2003, 02:31 PM   #11
Truckstr
Truckstr's Avatar
That's kind of what I was thinking. If you have HEI, then you'd just hook it in with the switched "hot" to the "BATT" terminal at the distributor. Right?
Jeff
'67 short Fleet; my ongoing project.
'66 long Fleet; my original "baby."
Live life or bust trying.
Truckstr is offline   Reply With Quote
Old 01-15-2003, 03:03 PM   #12
Bob Chayer
I'm not sure about the HEI. I like to run stock with a Pertronix pick-up.
Anyone know about the HEI?
Bob Chayer
Old 01-15-2003, 05:12 PM   #13
Truckstr
Truckstr's Avatar
Bob, I am only going off of the fact that the wire that I'm talking about on the HEI is a "switch on - hot" connection. That's why I feel like it would be Okay to use for this purpose.
However, as I've said before, I'm NOT an "electrical type", so I will defer to others for the definitive answer.
Thanks,
Jeff
Jeff
Old 01-15-2003, 07:27 PM   #14
Bob Chayer
Sounds the same as an external coil. Put a meter on it and if it is 12 volts when switched on with the key you are golden. Atleast with HEI you don't have to wory about determining if you have a 6 volt coil and conection. All HEI are 12. It doesn't work too well hitching up a 12 volt choke to a 6 volt sourse!
Let me know how it goes!
Bob Chayer
Old 01-16-2003, 09:34 AM   #15
Truckstr
Truckstr's Avatar
Bob, I haven't got a carb with an electric choke - yet. I'm still using the divorced choke Q-jet. Dinosaur tech LOL.
I have an Edelbrock RPM Air Gap manifold - new in the box. I'm just trying to decide if I want to try to put it on my current 350 and come up with a new square bore carb (and probably a hotter cam), or wait till I get my 406 built.
Decicions, decisions.
I know from some recent tests that I did that there IS 12 volts to the terminal on my HEI that I refered to. But I didn't know whether someone else may be aware of some unforeseen problem that hooking it up there would cause.
Just looking for that "voice of experience".
Thanks,
Jeff
Jeff
Old 01-16-2003, 12:01 PM   #16
Bill72BB
Bill72BB's Avatar
Jeff'
I have my HEI and Electric choke sharing the same 12v source no problem.
BILL
Member DUF Club
Old 01-16-2003, 02:30 PM   #17
Truckstr
Truckstr's Avatar
Thanks, Bill. I couldn't see any reason why not to do it, but...
Thanks again,
Jeff
Jeff
Thread Tools
Display Modes
