Old 09-16-2009, 03:00 PM   #1
87Bob
Rear end ratio?
I have an 85 LB 1/2 ton 305/350 does any one know what the stock rear end gear was? The build sticker in the glove box says standard rear end. I had heard that if you jack one rear wheel up and turn the drive shaft by hand counting how many revs it takes to make the wheel turn one time you can use that as a ratio. Can anyone confirm that?
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 09-16-2009, 04:58 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: Rear end ratio?
2.73 is stock.but you would have to open the cover and count the teath
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-16-2009, 05:22 PM   #3
menace121978
menace121978's Avatar
Re: Rear end ratio?
yes counting the teeth would be more exact but you can raise it up and i think both tires have to be in the air... 1st mark the drive shaft somehow and spin the wheel a full turn while counting how many times the drive shaft goes around. some say to do it in 3 spins and divide by 3 but i dont think its necessary.
say the driveshaft goes around 2 3/4 times you have a 2.73. goes around a touch over 3 you have 3.07. etc...
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-16-2009, 11:52 PM   #4
TurnNBurn
Re: Rear end ratio?
a standard rear is 3.07. seen them many times
TurnNBurn is offline   Reply With Quote
Old 09-17-2009, 01:23 PM   #5
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Rear end ratio?
My SPID says something like "standard rear axle, 2.76 ratio".
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-17-2009, 09:35 PM   #6
TwoFiftyShifter
Re: Rear end ratio?
My spid says sometihng like
code 05969490ejq11b
I don't remember it being easy to follow.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 09-17-2009, 11:07 PM   #7
Desert1957
Desert1957's Avatar
Re: Rear end ratio?
It was NOT the standard rear ratio........
2.73
Desert1957 is offline   Reply With Quote
Old 09-18-2009, 12:20 AM   #8
LiveAnimals
LiveAnimals's Avatar
Re: Rear end ratio?
huh I always thought they were 3.08s, learn something new everyday
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 09-18-2009, 01:54 AM   #9
2tons of fun
Re: Rear end ratio?
not realy seeing as how not every truck was built the same and 2.73, 3.08, 3.42, and 3.73 are all perfecty possible gears in any matching truck.
2tons of fun is offline   Reply With Quote
Old 09-18-2009, 03:09 AM   #10
shrtbx
Re: Rear end ratio?
very true...not every truck is built the same. The owner that had mine left a little thing in the glove box that looks like a credit card. It has all the options that he bought for it on the card. You can never tell with chevys from my experience. The first vette that i owned had all kinds of non typical options on it.
shrtbx is offline   Reply With Quote
Old 09-18-2009, 07:14 AM   #11
dbmx66
Re: Rear end ratio?
yea i have one of those too
dbmx66 is offline   Reply With Quote
Old 09-18-2009, 08:26 PM   #12
86k10
Re: Rear end ratio?
look next to where it says rear axle standard there should be an axle code.
98 Neon
97 Grand Prix GT
02 Grand Prix 40th Anniv.
86 GMC 5.0
77 Olds 98 6.6
REAL AMERICANS, DRIVE AMERICAN
86k10 is offline   Reply With Quote
Old 09-19-2009, 12:19 AM   #13
TeamRinaldi
TeamRinaldi's Avatar
Re: Rear end ratio?
mine's an 85' SB that was originally 305/350, now 350/350. Stock 2.73's.
TeamRinaldi is offline   Reply With Quote
Old 09-19-2009, 01:25 AM   #14
kenm78
Broken Down
kenm78's Avatar
Re: Rear end ratio?
My sticker in the glove box for my 1980 says 3.07
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 09-19-2009, 11:22 AM   #15
asphaltburner
asphaltburner's Avatar
Re: Rear end ratio?
Yo! My axles have a code stamped into the back of the axle tube that can provide the factory ratio, but that guarantees nothing. I like the idea of counting revolutions of the driveshaft,...that at least gives you info on what's actually installed.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 11-15-2009, 10:54 AM   #16
lakeroadster
Re: Rear end ratio?
To check rear end ratio jack up one tire if you have an open diff, or both tires if you have a working posi or locking differential. Rotate the tire one full revolution for posis and lockers and 2 full revolutions for open diffs. Carefully count the number of full revolutions the driveshaft makes. This is your gear ratio. In other words, if the drive shaft turns 3 ¾ turns, you probably have a 3.73 gear ratio. Turning the tire for twice the number of full revolutions and dividing the drive shaft revolutions by two will give you a more accurate reading.
lakeroadster is offline   Reply With Quote
Thread Tools
Display Modes
