Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-21-2009, 11:56 PM   #1
Captainfab
60-66 Nut
Filling Nitrous Tanks
Do any of you guys here fill your own tanks? If so how are you doing it?
My son and I are looking into filling his tanks ourselves to save a little $$. I can get a 35# tank for $78. Not a huge savings, but every little bit helps. We're aware of freezing the empty and filling from a supply tank, and of course the typical filling setup with a pump and all. We're just looking for the most economical way to do it.
Old 09-22-2009, 01:43 PM   #2
djracer
djracer's Avatar
Re: Filling Nitrous Tanks
If you can get the large tank without a dip tube you can invert it and you will get more of the nitrous out of the mother bottle. I was told with a pump you can fill a bottle with air but you can not by transfer filling. I ellected to transfer fill mine. You need a good scale also because you can over fill the bottle. If you over fill the bottle the pressusre has no where to go and they pop the safty valve much easier. I only put 9 pounds in a 10 pound bottle and it keeps the bottle pressure more even on a run.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 09-22-2009, 11:06 PM   #3
Captainfab
60-66 Nut
Thanks for the reply Kevin.
So to put together a transfer setup do you just make up a hose to connect the two cylinders?
Old 09-23-2009, 12:07 AM   #4
djracer
djracer's Avatar
I use a hose and a ball valve.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 09-23-2009, 07:25 AM   #5
franks72
Junior Member
franks72's Avatar
Do you freeze your bottle before transfer.
72 cheyenne super BB402 TH400 Air Tack Tilt Posi P/S P/B AM/FM 12.96 @ 101.82 mph 60ft 1.82
12.39 @111.33 With a 180 shot nos
69 Camaro RS http://s94.photobucket.com/albums/l117/fdelcoglin/
email fdelcoglin@hotmail.com
franks72 is offline   Reply With Quote
Old 09-23-2009, 04:54 PM   #6
djracer
djracer's Avatar
Yes
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 09-23-2009, 11:39 PM   #7
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Kevin is spot on. I have gone to bulk gas yards and try to get medical grade. I was told it was cleaner. I also use a in line filter.
68 C-10 KID is offline   Reply With Quote
Old 09-24-2009, 12:31 AM   #8
Captainfab
60-66 Nut
I was told I couldn't get medical grade without a license to dispense it.
Old 09-25-2009, 05:30 PM   #9
scatesracing
Machinist
scatesracing's Avatar
My friend has a pump... seems to work fine and i dont have to wait on the bottle to chill down... medical grade has no sulfer in it so it is oderless . thats why they dont want it in our hands... I know that "they" have given us medical grade before but i dont think "they' are supposed to. Might just be a state law though
scatesracing is offline   Reply With Quote
Old 09-25-2009, 06:15 PM   #10
djracer
djracer's Avatar
The pumps work but they cost way too much and I hear they don't hold up.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 09-25-2009, 11:37 PM   #11
Captainfab
60-66 Nut
I picked up a 50# cylinder today and got a couple of hoses made also. It should work fine.......I'll let you guys know if it doesn't for some reason.
Old 09-27-2009, 04:01 PM   #12
team39763
I've been getting screwed on my mother bottles. I got 36lbs out of my last bottle. I was supposed to be getting the "family member hook-up", but I guess not. I'm gonna try a bottle without a siphon tube this time and see how that works out. I also have a NX pump, but my first refill went bad...it had a lot of air in it. So now I freeze fill. I may try messing with the NX pump again, but for now it's a $1400 paperweight that's only been used 1 time.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 10-02-2009, 01:02 PM   #13
hotrod 80
mini truck racer
hotrod 80's Avatar
Chill your 10 #er down and crack your mother bottle , use a wrench to crack the hose fitting at the 10# bottle to purge air from the line . Weigh it in . If you suspect air in bottle . Invert filled bottle with dip tube in top corner and purge bottle to remove non condesables . A ball valve as mentioned before will save the gas in the line . You should be able to get all but about 6#s out of a full size mother bottle .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 09-27-2011, 05:23 PM   #14
bbadfred
bbadfred
bbadfred's Avatar
I have a fill station if you live in the east central illinois area I sell it for 5 bucks a lb which helps pay my yearly bottle rent. I am in rantoul Il. 217 202 8038.
bbadfred is offline   Reply With Quote
Old 09-27-2011, 09:30 PM   #15
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
this is true
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 10-05-2011, 10:59 PM   #16
hotrod 80
mini truck racer
hotrod 80's Avatar
It does happen though with bottles being mixed up now and then .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Thread Tools
Display Modes
