Old 09-22-2009, 03:24 PM   #1
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Single vs. dual exhaust
Just asking for opinions. My truck currently has dual 2 1/2 exhaust with Flowmasters. I need to re-do the exhaust because it hangs waaaaay too low. I am going to buy some shorty headers and go from there. I was thinking a y-pipe and single 3 inch exhaust is the way I am going to go to save room under the truck and clean things up a bit. What are your guys experiences and opinions? Thanks in advance.
--Josh
Old 09-22-2009, 03:40 PM   #2
Storm Chaser
Storm Chaser's Avatar
Re: Single vs. dual exhaust
Don't think it will sound as good as duals... plus duals are more efficient
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 09-22-2009, 04:28 PM   #3
shrtbx
I have a single exhaust set up similar to what you are talking about and i like it. 3inch y-pipe that came with my hookers to a single 3 inch in double 3 inch out right before the rear wheel. It has a killer sound to it and flows great.
shrtbx is offline   Reply With Quote
Old 09-22-2009, 04:29 PM   #4
Pyrotechnic
Pyrotechnic's Avatar
People with lowered trucks have had good luck with Chevelle headers. They are mid length and don't hang that low. You can fabricate a nicely tucked dual system with these. Infact, if the rest of your system from the end of the transmission back was done right and isn't hanging too low, you might be able to install the Chevelle headers then have the existing system adapted to them.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 09-22-2009, 04:55 PM   #5
STOCKISH
STOCKISH's Avatar
Buying the mid lengths are also an option I am considering. Just havent decided yet.
--Josh
Old 09-22-2009, 05:59 PM   #6
JohnC
JohnC's Avatar
Not to get off topic, but is there any particular year of Chevelle that works better, or will any of them work?
Personally I would run duals. I've never seen a single exhaust that big done so I don't know how it would rate effiecency, and sound wise compared to the duals.
JohnC is offline   Reply With Quote
Old 09-22-2009, 06:01 PM   #7
shrtbx
I dont know the exact part number of mine but they are hookers made specifically for our years mine came with the huge front y pipe as well. I cant see the pipes at all except for the two exhaust pipes coming from the muffler. The entire system is designed to run up and over the transmission mounting bracket so its actually tucked up high. if i didnt have it exiting from the side i could slam the truck completely to the ground and have no clearance problems.
Old 09-22-2009, 06:03 PM   #8
JohnC
JohnC's Avatar
Do you have any pics of it shrtbx?
Old 09-22-2009, 06:16 PM   #9
shrtbx
I can take some tonight.
Old 09-22-2009, 06:17 PM   #10
big10ratrod77
big10ratrod77's Avatar
duel is better i had the stock single exhaust for like all summer on my big 10 and it was like weak as mess so then the week before school started i had a local muffler shop to run me some 2 1/4 duels with an h pipe and some summit turbo mufflers (it was like 250for everything) and it runs great now big difference in sound and power
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 09-22-2009, 06:39 PM   #11
f.monroe
f.monroe's Avatar
I would ask Ken for an opinion on this subject . His black Cheyenne has/had an awesome custom single exhaust that I think he was very pleased with . You might ask what his specs were .I have had both and on my 87 shortbed I once had , I ran a single 3 inch exhaust . I ran a 50 series and it sounded good . It had a nice roar under heavy throttle also .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 09-22-2009, 09:37 PM   #12
asphaltburner
asphaltburner's Avatar
Yo! Here's a pic of FRANKENTRUCKs' 2.5" dual exhaust with "H" pipe:
Name:  101308 002 (Custom).jpg
Shorty headers and Summits' "H" pipe and offset turbo mufflers. Sounds fantastic, and this exhaust does NOT sit low!
You'll certainly breathe and sound better with 2.5" duals than with a single 3", and the crosspipe helps scavenge exhaust gases even better than true duals,...easy to install too.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 09-22-2009, 11:53 PM   #13
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Todd, you are fortunate...Frankentruck has the clearance for that H pipe. That would never clear under mine. I built mine in true duals, turbo mufflers, and exits right in front of the rear tires. When the funds are there I will be getting the Chevelle headers for the extra flow.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 09-23-2009, 09:39 AM   #14
asphaltburner
Yo! Yeah, I sure can't get an "H" or "X" pipe under my Camaro, just sits too low and no room on either side. Your setup is exactly what it has and I'm sure yours sounds just as devilish!
FRANKENTRUCKs exhaust has that great sound too, but straight out the back.
Sure hope this gives 1972SuperCheyenne some great examples and ideas!
I must say, I DIDN'T think they could shoot that passenger side 2.5" tube between the t/case and frame, but it sure came out beautiful! Ken's Mufflers in Ft Collins did a magnificent job for a great price!
Todd.
Old 09-23-2009, 12:29 PM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by f.monroe View Post
I would ask Ken for an opinion on this subject . His black Cheyenne has/had an awesome custom single exhaust that I think he was very pleased with...
Unfortunately the new Ridetech AirBar system demanded that it be changed, but I was very pleased with my single system.
You probably won't want to go through the expense that I did, but I started with 2.5" Corvette "ram horn" manifolds. From there I had a Y-pipe custom built that hugged the motor and transmission. Coming out of the Y w ran 2.5" pipe to a high flow catalytic, then back to a single in/single out Flowmaster. The tailpipe went to the rear corner of the bed and had a slight turn down.
Thi system flowed very well and maintained a very quiet sound inside the cab. It had a nice rumble that came to life when I stomped the loud pedal.
Yes, true duals with an H or X pipe are the best flowing available. If your not concerned with a slight loss in performance, a single system is cheaper, cleaner, and still sounds good.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-23-2009, 12:53 PM   #16
Prerunner1982
Prerunner1982's Avatar
He isn't comparing duals to stock single. He is comparing dual 2.5" to single 3"...
For a stock or mild SBC I think either would be fine. I had dual 3" on my 82 Silverado and though it sounded great I think it was a bit too big for a stock 350.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 09-23-2009, 01:24 PM   #17
STOCKISH
STOCKISH's Avatar
I was thinking about having a 2 1/2 y-pipe custom made in to single 3 inch through a Flowmaster super 40. The way the trans crossmember is on this truck it is just easier to run a big single exhaust. The price isn't an issue, just want it done right the first time so I can move on to installing my serpentine belt stuff.
--Josh
Old 09-23-2009, 01:45 PM   #18
menace121978
menace121978's Avatar
i agree with this. I've had 5 different set-ups on mine and the last one was all custom from the headers to y-pipe all 3" into a single in duel out 40 series w/ 3" tail pipes. sounds awesome but i know there was a loss in torque w/ the stock bolt on 350.
SuperCheyenne, if you do go w/ the y-pipe make sure they route it away from the trans pan. mine had maybe a 1/2" clearance between the pan and the huge 3" pipe and it still seemed to hang kinda low and the tranny would get hot as heck. My advice (and what i'm going to do next) would be true duels with an h-pipe after the tranny pan tucked up as high as i can all stainless with mid length headers into 50 series flows all 2 3/4" all the way out to the rear lower quarter panels on each side pointing down like the old camaro's. good luck deciding man. i'm never happy with exhaust! (besides a fox body i had 1 time)
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Thread Tools
Display Modes
