Old 09-23-2009, 07:12 PM   #1
brothers69c-10
Suburban Hick
brothers69c-10's Avatar
56" springs on a half ton?
Anyone ever put 56" long springs on the rear of a half ton 4wd? I've been poking around on the internet and have read about some people who want to try it. I am putting 3/4 ton axles under my half ton and want to beaf up the rear springs and all the 3/4 tons that had the 56" springs, even though they had more leaves, always rode better than my half ton with 52" springs. I know where there is a set of 1 ton 56" springs i could get pretty reasonable and they would be perfect since i'm going to put a gooseneck hitch in the bed and yes i'm going to beef up the stress points of the frame. Anyways any and all input is always appreciated.
Mathew
Mathew
1947 Chevy 3600
1951 GMC 100
1969 Chevy C-10 396/500hp TH400 lowered 4"
1968 Imapla Custom 396/325hp TH400 "Grandmas Car"
1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505
1978 Chevy K-10 454
1983 S10 4x4 "Bumblb" (Grandpa's truck)
1993 Chevy S10 V8 conversion
1990 Ford Probe Gt
1992 Dodge W-150 "Old Man's Truck"
1992 Pontiac Grand Prix SE
1992 Mercury Grand Marquis-Mercruiser
2000 Ford F150 (Currently my mother drives this)
1946 Farmall H with Stan Hoist loader
1965 John Deere 110
1961 Wheel Horse " Rat Tractor"
brothers69c-10 is offline   Reply With Quote
Old 09-23-2009, 07:44 PM   #2
James McClure
One shot, one kill.
Re: 56" springs on a half ton?
Brothers, you may run into drive shaft length issues with 56" springs. Also the added length, even with extra leaves, is going to affect vehicle control, they are wishy-washey leading to trailer "whip". I've dealt with whipping, and believe me, when that trailer tries to pass you your life will flow past your eyes & you'll leave a skid mark or two in your drawers. Stick with the 52"'s.jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 09-23-2009, 08:08 PM   #3
Pyrotechnic
Pyrotechnic's Avatar
GM did this from the factory. It was referred to as "Heavy Duty Chassis Equipment" on the option sheet. It was marketed as Big 10 (Chevy) or Heavy Galf (GMC).
Amongst many upgrades, one thing it included was the longer 3/4 ton leafs springs. The rear shackle hanger is simply mounted further back on the frame. All half ton frames have both sets of mounting holes, it's just a matter of drilling/grinding out the rivets then bolting the hangers back in the appropriate position.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 09-23-2009, 08:55 PM   #4
87Bob
What about the earlier post about the drive shaft length if you do what you suggest? Also my 85 is listed as having a heavy duty spring could you have a HD spring that wasn't the longer one?
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 09-23-2009, 09:20 PM   #5
Pyrotechnic
Driveshaft length stays the same, wheelbase stays the same.
The short and long springs are identical length ahead of the axle mounting point. The long springs get their extra length behind the axle, and the shackle hanger is moved back to compensate.
Old 09-23-2009, 09:30 PM   #6
tomtuna1978
i just did this mod on my 79 gmc short bed 4x4. i did it for the lift and the softer ride, not to tow anything. i got the ord kit and some 56inchers from the local pick a part. i love how the rear rides now and would do it again in a heart beat! and im thinking or buying the kit to put my 52 inchers in the front because the tough country 4 inch lift springs ive got in the front are pretty stiff! i dont know about the towing characteristics when doing this mod, id prolly wait for some more poasts
tomtuna1978 is offline   Reply With Quote
Old 09-23-2009, 09:37 PM   #7
brothers69c-10
Suburban Hick
Thanks for the reply guys. Considering that one tons came with the56ers and so did most of the 3/4's i think they should tow just fine especially with a 9 pack of leaves. I forgot about the conversions for the front springs. I had thought about putting 49and a 1/2's up front once, but may wait till another day for that one.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 09-24-2009, 12:19 AM   #8
asphaltburner
asphaltburner's Avatar
Yo! REALLY?!
I was SO worried that the 5560 lb rated axle/spring combo from my donor 3/4t flatbed was gonna ride so rough in my 3/4t P/U (4800lb axle/springs origonally),...and it's so smooth! Sure love my result! Mine was a direct swap though, '73 flatbed to '78 P/U (both 3/4t), so I didn't have to worry about incompatibilities.
Cool, Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 09-24-2009, 05:45 AM   #9
bigblock73
yeller
bigblock73's Avatar
both my 1/2 tons have the 8 leafs 56'ers from the factory. Buy the springs, move the rear hangers back, install the springs, call it a day. Truck will run/drive just fine, drivesahft won't be an issue. Be sure to get all new grade 8 hardware, and use anti-sieze.
bigblock73 is offline   Reply With Quote
Old 09-24-2009, 09:06 AM   #10
brothers69c-10
Suburban Hick
Grade 8 is a definite and I always forget the anti-seize.
hanks for the input.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 09-24-2009, 12:22 PM   #11
bigblock73
yeller
bigblock73's Avatar
FYI
The bolts are 9/16", 4.5" long, coarse thread. If you need U-bolts, they are 5/8", 3" inside diameter, 8" long.
Just trying to save you a trip to the HW store in the middle of your project.
Old 09-24-2009, 06:18 PM   #12
brothers69c-10
Suburban Hick
Thanks jeff i will write that down. I already got brand new u bolts. The guy i'm getting the springs from was going to put a 4 inch lift on his brothers truck then opted for a 6 inch. So free bolts equals it's finally time to put the lift kit on!
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 09-27-2009, 10:48 PM   #13
brothers69c-10
Suburban Hick
Next question, what i have to do is move the the REAR spring mount back 4 inches correct?
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 09-27-2009, 10:54 PM   #14
KQQL IT
At the body shop.
KQQL IT's Avatar
The holes should already be there cut the rivets and bolt them down at the new spot.
KQQL IT is offline   Reply With Quote
Old 09-28-2009, 12:31 AM   #15
2tons of fun
yes. x2
2tons of fun is offline   Reply With Quote
Old 09-28-2009, 03:21 PM   #16
brothers69c-10
Suburban Hick
There are no holes on my frame. Are you guys referring to 4x4 or 2wd frames? and yes my springs are 52 inches long i double hecked when i couldn"t find any holes.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 09-28-2009, 07:54 PM   #17
lolife99
67-72 parts collector,…
lolife99's Avatar
Got any pics of the rear frame area?
Keith
Convert to disc brakes.
Old 09-28-2009, 08:22 PM   #18
bigblock73
yeller
bigblock73's Avatar
My 2wd has both sets of holes...but am not sure about 4wd frames.
Old 09-28-2009, 08:29 PM   #19
brothers69c-10
Suburban Hick
No pics, but i looked at a 3/4 ton frame and it didn"t have holes for the 52's not that it means anything. I was measuring and if i move the rear spring hangers back 4 inches i may have to grind down the bumper brackets.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 09-28-2009, 08:40 PM   #20
bigblock73
yeller
bigblock73's Avatar
No you don't. On my 56" 1973 and 1977 C10's, the rear hangers are about 1/8" apart from the bumper brackets. Just slide the hangers back to the bumper brackets, the shackles will take care of any minor difference there may be.
Old 09-28-2009, 10:16 PM   #21
brothers69c-10
Suburban Hick
Ok, I think i can get way with that. I am putting a lift kit on it at the same time so that should help with the play.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Thread Tools
Display Modes
