Old 09-25-2009, 02:30 PM   #1
75sierraclassic
75sierraclassic's Avatar
Defroster Duct Doesn't Blow
Well its starting to get a little chilly in the mornings and I recently noticed by defrost vent isn't working. What do you guys think is the most likely culprit? The hot/cold lever works, the A/C still turns on, it just seems that some of the dampers aren't working that redirect the air to the defroster vents. Vacuum leak somewhere, bad diaphragm, vacuum switch? If the hot / cold lever still works does this mean that the vacuum switch is good and its a diaphragm or vacuum leak somewhere?
75sierraclassic is offline   Reply With Quote
Old 09-25-2009, 02:38 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: Defroster Duct Doesn't Blow
There is a vacuum line under the hood that is most likely unhooked or split. Mine is right behind the carb and hooks to a manifold vacuum source. Take care.
--Josh
Old 09-25-2009, 02:49 PM   #3
77gmcjoe
What do we get for $10?
77gmcjoe's Avatar
I had trouble with no air blowing out of the defrosters on a couple of different trucks, one time it was a bad vacuum pod and the other was a rotted hose going to a vacuum pod. Unfortunately I had to pull the whole plenum assembly out from under the dash to get to both of the problems.
1977 GMC K25 400/400/205
1989 Chevy Suburban R1500 350/700R4 (work beater)
1994 Chevy K3500 dually 454/4L80
1996 Corvette LT4 350/ZF 6 speed
2000 Bonneville SSEI Supercharged 3.8 Liter V6
1966 Chevelle 2 door sedan (Needs major repair )
77gmcjoe is offline   Reply With Quote
Old 09-28-2009, 09:46 AM   #4
75sierraclassic
Thanks for the info guys, found a rotted vacuum line under the hood. She's blowin again
Old 09-28-2009, 10:28 AM   #5
STOCKISH
STOCKISH's Avatar
Sweet, glad you got it fixed. Missouri will turn to Misery real quick with no heat.
--Josh
Old 09-28-2009, 11:28 AM   #6
kelsfine69
18 Till I Die
kelsfine69's Avatar
I was watching this thread hoping for ideas on mine. Mine all works but air bleeds from the a/c vents when on heat and defrost. Mayby I will wait till the core craters then I will pull it all out. i was hoping for an easy fix to a similer problem
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 10-19-2009, 01:05 AM   #7
632bbc
632bbc's Avatar
this may be a dumb question. . . but where does the vacuum pod get it's vacuum from? I found the line coming out of the cab but that's all. . . my heater is the same way. . no defrost or floor just blows out the vents
632bbc is offline   Reply With Quote
Old 10-20-2009, 12:06 AM   #8
77nomad
77nomad's Avatar
Location: Muskegon, MI (the beer tent capitol of the world)
There is a tiny kind of hard plastic vac line under the hood that gets engine vacuum. Mine is teed into carb base.
77nomad is offline   Reply With Quote
Thread Tools
Display Modes
