Old 09-27-2009, 09:49 AM   #1
ts71281
What's the proper way of restoring the paint in your side trim?
When I restored my truck years back my trim was in decent shape, however the satin black paint was horrible.. I sat down with lacquer thinner and a rag and stripped it down perfectly clean. Now I'm wondering how I can restore the black paint in the trim. Do you guys use adhesive vinyl or paint? Also, how do you get the little thin areas in the upper moulding?
ts71281 is offline   Reply With Quote
Old 09-27-2009, 10:18 AM   #2
jwn1975
Re: What's the proper way of restoring the paint in your side trim?
I stripped them as you did and masked off the area on the lower with masking tape. I then lightly scuffed them with a grey 3m scotch pad. I "dusted" them with selfe etching primer in a rattle can and then sprayed them with rattle can "trim black" from NAPA. They turned out GREAT with the new wood grain stickers. On the top moulding i masked them off with thin blue masking tape from napa, dusted them with selfe etching primer and painted them.
jwn1975 is offline   Reply With Quote
Old 09-27-2009, 10:58 PM   #3
mclairmo
Krylon Satin black should be a good match, too. I use it for everything.
mclairmo is offline   Reply With Quote
Thread Tools
Display Modes
