Old 01-15-2003, 11:05 PM   #1
chris
blazer swap
does anyone know if a 67-72 blazer body will fit on a 91 blazer frame?
chris is offline   Reply With Quote
Old 01-16-2003, 04:10 AM   #2
Mudder
Mudder's Avatar
Ya need to do a lot of measuring!
Mudder is offline   Reply With Quote
Old 01-16-2003, 11:57 AM   #3
Mike C
Mike C's Avatar
Anything can be done with a welder and a little initiative... But the 91 truck has a 108" wheel base and the early truck is 104". You would either have to lift the he!! out of it or have custom springs made with relocated pins (which might reduce spring windup significantly. Why would you even consider this, the trucks use same running gear, same steering, and same suspension design and axles? Just swap new parts on old truck, except for rear axle where re-welding perches is all that is required.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Thread Tools
Display Modes
