Old 10-03-2009, 08:45 PM   #1
CWS
Key Lock Issue
I have a 67 with manual door locks. Today I installed new door handles and new door key locks. (The PO removed the door handles and I did not have the key for the locks.) I lubed the locking mechanism inside the door and have it working smoothly. When I use the key to lock the door, it does pull the knob on the door down and prevents the door from being opened from the inside. But, I can open the door from the outside, when I use the new outside door handle it is not different from when it is unlocked. I have the same problem on both doors. The new door handles are reproductions that I bought from a site vendor.
Does anyone have any suggestions?
Craig
CWS is offline   Reply With Quote
Old 10-03-2009, 09:10 PM   #2
JimKshortstep4x4
Re: Key Lock Issue
Is the knob going all the way down?
Try pushing in on the doors when locking them.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-03-2009, 09:25 PM   #3
cdowns
cdowns's Avatar
Re: Key Lock Issue
or take off the knob to make sure it isn't preventing the rod from going all the way down
Old 10-03-2009, 10:07 PM   #4
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: Key Lock Issue
I doubt very seriously that the doorhandles are at fault. I installed aftermarket door handles on mine and they worked perfectly. We need to get Lockdoc in on this thread.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 10-03-2009, 11:02 PM   #5
CWS
Re: Key Lock Issue
A little follow-up to the suggestions. I only have a knob on one side, so I do not think the knob is preventing the lock from engaging. I think the reproduction outside door handles are fine. I am thinking when the doors are locked (and working properly), something in the latch mechanism prevents the door handle button from be depressed, hence locking the door from the outside. My manuals don’t have a good schematic of the locking mechanism, and I can not get a good view of it, to much door structure blocking the view. Does anyone have a schematic of the locking mechanism or any additional suggestions?
Craig
Old 10-03-2009, 11:40 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Re: Key Lock Issue
You don't specifically mention this but are you locking the door from the outside with the key or are you pushing the button down and closing the door? You can't do the latter with these trucks, you have to lock them from the outside with the key, after you close the door.
Have you put new weatherstrip on the doors? If so and the doors are tight and hard to close the lock will not work correctly.
LockDoc
Leon
Old 10-03-2009, 11:56 PM   #7
CWS
Re: Key Lock Issue
I have been closing the door then using the key to lock the door. Have not put any new weather striping on the truck. I would not say the door is hard to close, but it isn't easy to close either. Is it possible that the latching mechanism is just worn-out? I can look at trying to realign the latch/strike plate if you thing that will help.
Thanks for the help,
Craig
Old 10-04-2009, 12:07 AM   #8
LockDoc
LockDoc's Avatar
Re: Key Lock Issue
Craig
Did you try pushing in on the door as you turn the key to lock it, as JimKshortstep4x4 mentioned?
You can try moving the striker plate on the door jamb out a little bit. Be sure to mark around it with a fine marking pen first so you know how far you have moved it. I would try 1/16th or 3/32nds at a time. If that is the problem it shouldn't take much.
I can't believe both latches would be worn enough that the doors wouldn't lock.
LockDoc
Leon
Old 10-04-2009, 01:12 PM   #9
CWS
Re: Key Lock Issue
Thanks for all the help. Moving the strike plate out about 1/16th of an inch is all it took.
Old 10-04-2009, 02:39 PM   #10
LockDoc
LockDoc's Avatar
Re: Key Lock Issue
Glad that took care of it.
LockDoc
Leon
Old 10-12-2009, 09:45 PM   #11
ebbhightower
Re: Key Lock Issue
wrong posting
ebbhightower is offline   Reply With Quote
Old 10-20-2009, 10:56 PM   #12
howard_m18
howard_m18's Avatar
Re: Key Lock Issue
I have a 67 that I'm rebuilding & have posted it under the builds. We are getting ready to install Electric-lift power dr. loks & have come up with a problem already? The rod clamp can't go over the rod as the rod is close to 1/4 & the clamp are for a much smaller rod? I didn't get a chance to call the tech help line, will tomorrow. The power windows, no problems.
1967 C10 LWB, painted 2010 MUSTANG GRABBER BLUE & finally got it on the road after sitting in garage for 10+ yrs. Howard in MI.
howard_m18 is offline   Reply With Quote
Old 10-20-2009, 11:15 PM   #13
LockDoc
LockDoc's Avatar
Re: Key Lock Issue
You can buy the same type clip for 1/4" rod. You might try the clip from a rod type throttle linkage used on '67 and maybe '68. I think 6 cyl. throttle linkage uses the 1/4" clip too.
LockDoc
Leon
Thread Tools
Display Modes
