Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 01-16-2003, 09:48 PM   #1
67cst
i love summertime
67cst's Avatar
OT: potato cannons
hey guys i got a question, im in the middle of building another potato cannon...my question is i wanna use a spark plug on this one, how can i get a spark to it?? easyest the best...also lighter the better, would a 9v battery work? thanks in advance guys
Derek
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 01-16-2003, 09:53 PM   #2
ozarkhippie
hehe I still have one, I haven't heard of using a spark plug though.
Buy Sale or Trade
71 3/4 4x4
72 1/2 ton cheyenne 4x4
ozarkhippie is offline   Reply With Quote
Old 01-16-2003, 09:55 PM   #3
oldyeller
Captain CAAAVVVMMMAAANNN!
oldyeller's Avatar
well, you could use a flame thrower set up, 12v battery and a coil, 9v might work, but you will still need a coil, there about 9 bucks new at the local parts store for a cheap one..
72 LWB Fleetside C10 Custom 350/350
97 GMC Yukon 4X4 SLT
Anna, Texas
check out the project old yeller
oldyeller is offline   Reply With Quote
Old 01-16-2003, 10:00 PM   #4
67cst
i love summertime
67cst's Avatar
old yeller? pls explain
Old 01-16-2003, 10:03 PM   #5
67cst
i love summertime
67cst's Avatar
also i have a psi gauge for the combustion chamber, when the explosion occurs will this destroy the gauge?
Old 01-16-2003, 10:09 PM   #6
Steven Sellers
Steven Sellers's Avatar
Hehe the gauge unless it is rated for much higher than the force the explosion will cause, will be destroyed.
2008 Buick Enclave(wifes new non wrecked)
1996 Jeep Cherokee
2002 2500HD 6.0L (traded)
1998 Jeep Grand Cherokee(wifes/wrecked)
1977 DJ5 postal jeep(mmm lots of fun)
1988 Toyota 2wd p/u(DD, blewup 199,000)
1991 Toyota 2ed p/u (sry just cant break these things)
1997 XR70 Honda
1991 Z50(FOR SALE)
1972 Z50 Honda
1970 SWB 350/knucklebuster "The adventure begins and I am confident that there will be no end".
Steven Sellers is offline   Reply With Quote
Old 01-16-2003, 10:22 PM   #7
67cst
i love summertime
67cst's Avatar
if i had a valve in between the chamber and gauge would that work, like when the propane is going in the chamber have the valve open and once i reach operating psi i close the valve before firing?
Old 01-16-2003, 10:23 PM   #8
Steven Sellers
Yes but the problem would be is making sure you get a decent one so it holds. The gauge definetly would not take the shock
1996 Jeep Cherokee
1997 XR70 Honda
1991 Z50(FOR SALE)
1972 Z50 Honda
Old 01-16-2003, 10:29 PM   #9
67cst
i love summertime
67cst's Avatar
okay, also i wanna have a propane tank mounted beside the chamber, and a hose off the propane directly hooked to the chamber, with a valve...but im having problems finding something that will thread onto the propane that will also push that pin in to realease the gas...what would work in that case
Old 01-16-2003, 10:32 PM   #10
GMC71k20
i made a potato gun for a school project but they wouldnt let me bring in my combustion propelled one so i made one out of PVC piping that would run off compressed air, stomp the valve really quick and it did much better than my other one.
GMC71k20 is offline   Reply With Quote
Old 01-16-2003, 10:35 PM   #11
67cst
i love summertime
67cst's Avatar
gmc71k20-im making one at trade school, in the welding shop, my teacher likes the idea but its sorta on the downlow, i pretty much have it all welded up but now i gotta do the thinking....
Old 01-16-2003, 10:55 PM   #12
still w.i.p '68
Dreams are free
still w.i.p '68's Avatar
Unless you are just wanting the sprak plug, I find it easiest to use an ignitor off of a BBQ grill , its self contaned, requires no batterys, and is quick like a trigger....Good luck, and let us know, Oh by the way , have you ever built a tennis ball cannon, the ball is used over, and over..
'68 swb fleetside
originally w.i.p '68
member since 1-01
w.i.p = ( work in progress )
still w.i.p '68 is offline   Reply With Quote
Old 01-17-2003, 12:46 AM   #13
67cst
i love summertime
67cst's Avatar
nope never have...how do they work...?
Old 01-17-2003, 12:48 AM   #14
oldyeller
oldyeller's Avatar
are you using a 20 lb propane tank, like for a BBQ? why not go to walmart and get a new hose and connector for a BBQ that would connect to the tank, this would solve your fuel supply problem..
As for the spark plug, get one that is long( has alot of threads) that way it will stick into the pipe close to the center. use a coil plug wire to go from the coil to the spark plug, then wire the coil coil to the battery with a monotary switch ( the type that makes contact when you push it and is open when you let off) in the positive lead. This way you will gas up the chamber, close your fuel valve( make sure it is a good one so it doesn't flame up your hose and blow your tank and you up) and hit the button, when you hit the button it will send about 30,000 volts to the plug, so watch where you hang on to it, it will hurt...
they just did a flame thrower install on the show trucks this last weekend... watch for a rerun
Anna, Texas
Old 01-17-2003, 12:53 AM   #15
67cst
i love summertime
67cst's Avatar
i have a green coleman propane tank (16oz) the big bbq propane tanks have different fittings...hmmmm
Derek
Old 01-17-2003, 01:07 AM   #16
Hooter
My other Love
Hooter's Avatar
I usually just use a Bbq sparker and some hairspray . Don't you just love the sound of a spud gun?!
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 01-17-2003, 01:21 AM   #17
chevykid04
4 speed, hurst shiftin
chevykid04's Avatar
me and my friend are in the process of making one....grill igniters, work great.also sometimes, if you wrap a peice of paper around the bottom of the potatoe, it makes a better seal and more friction = more distance my friend who use to work at my work , would shoot them out the exhaust hole in the door, over the freeway
Shane
1970 Chevy C10
chevykid04 is offline   Reply With Quote
Old 01-17-2003, 02:06 AM   #18
Mitzki5
"TRUCKLESS"
Mitzki5's Avatar
I see a couple problems with your idea. First, not only will you need a propane bottle but you would also need a way to put air in with the propane. Then you have to figure out the correct ratio of air to propane. Don't bother with the gauge. You will not be able to pressurize the combustion chamber. Once you stuff your potato in and try to pressurize, the pressure will push the potato out. You only need to pressurize the chamber if you are making a pneumatic launcher rather than a combustion launcher. I agree with the other people. A grill ignitor works the best. Another tip that I have read and applied to my laucher is to make sure the size of the combustion chamber is double the barrel (potato shoot) is. I used a 4" diameter pipe for my combustion chamber with a 2" pipe for the barrel. Here's a website I found a long time ago. I haven't checked it out lately.
http://www.spudtech.com/
By the way, potato guns are fun but they can be VERY dangerous. So be very carefull. The above post are just ideas and I am not held responsible for anything that you do with the info above. I know this is stupid to put this last paragraph on here, but it makes me feel better.
Mitzki5
No longer have an old truck! But always looking for another one!
Mitzki5 is offline   Reply With Quote
Old 01-17-2003, 03:41 AM   #19
whitdog72
man u guys are getting way to technical....the best thing i have seen with the most spark is a Lantern Lighter...i have seen them at Right aid, and Big 5 sporting goods i am sure any sporting good carries them, the thing is in the shape of and L ......the long end of the L is a twist nob which twist the other end where the 2 ends meet in the L has a flint or so on it it almost Work the same as a Torch Stricker......it will prolly be easier for me to draw a quick pic in paint then it will be to describe it......i have always used hair spray on my guns soo after a while the flint will get wet so u will have to let it dry a lil bit but we had one rigged to where wall nuts with the green shell on them would fit right in the barrel got them to launch a hundred yards or so good times! lemme know if ya wanna know more i'll try a quick pic of how mines set up
72 LB 4inch lift 33's 350/350t stage 2 shift kit
91 chevy 4inch suspension lift, 3inch body, 33inch swampers, chipped, stage 2 shift kit ( it kicks hard!), 4 JL audio W0 10's behind my seat,
and also my 72 cj5
AIM: whitdog72, FORDSSUC
whitdog72 is offline   Reply With Quote
Old 01-17-2003, 03:51 AM   #20
whitdog72
Kinda What it looks like
i have bought one before around 3 bucks or so like i said works the same and a torch striker or a cig lighter
and also my 72 cj5
Old 01-17-2003, 03:57 AM   #21
whitdog72
kinda what it would look like in the gun......put it in the middle for best spark i guess
and also my 72 cj5
Old 01-17-2003, 08:22 AM   #22
694X4
694X4's Avatar
I am building a pnematic one right now with a electric lawn sprinkler valve. This thing should be awsome the valve releases in like 1/10 th of a second. I also have one that burns hair spray and uses the lantern lighter and it works well. There is lots of stuff on the net about these.
69 3/4 ton 4x4 gmc with 6" sky jacker soft ride. 350 / th350 / 205
work in progress
694X4 is offline   Reply With Quote
Old 01-17-2003, 10:25 AM   #23
Yukon Jack
Post Whore
Yukon Jack's Avatar
How about some pumpkin chunkin - 67-72 style!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-17-2003, 10:36 AM   #24
694X4
694X4's Avatar
Hell yes that is awsome now it just needs to be 4x4 so we can take it to Iraq and run in the sand. Old Sadam wouldn't know what hit him if he got nailed in noggen with a 10 pound punkin.
work in progress
Old 01-17-2003, 11:55 AM   #25
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Here is how the one I used to have was set up. Just like Whitdog72's but instead of having the spark in the side I put an end cap on the big end of the pvc pipe and drilled a small hole in the center of it. I used a candle lighter that was only a buck or two at walmart. The ones that have the trigger and are about eight inches long. Most people have 1 or 2 around that are out of fluid anyway, and thats all the more better. Load potatoe, take the cap & long straw tube off a can of brake cleaner, wd40 whatever and put it on your hairspray can. insert tube in the hole, spray, insert candle lighter and pull trigger. WWhhooooomm. I have been thinking about using smaller pvc pipe, say 1" or 1 1/2" and instead of potatoes or tennis balls, trying snow. It's cheap and plentiful in some places. If I could have had one of these when I was a kid, those snow fort snowball fights would have been much more fun. Later............Jerry
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Thread Tools
Display Modes
