Old 10-13-2009, 03:52 PM   #1
kc69
Gas tank pressure??
Trying to get my 68' chevy sb 350 started, and it just cranks over and over. It ran for about a minute or two and then died. I then heard a hissing noise coming from my gas tank lid (pressure). Do you think my fuel pump is out, or could it be a clogged fuel sending unit screen, or something else. oh, and just put in a new fuel filter in the 2 barrel rochester.
kc69 is offline   Reply With Quote
Old 10-13-2009, 04:02 PM   #2
John Fabris
TOTY 2006
John Fabris's Avatar
Re: Gas tank pressure??
Sounds like your tank is plugged. What is happening is as you crank your engine, your fuel pump is pulling fuel out of the tank, creating a vacumn. As your engine runs, the vacumn in tank becomes too great and fuel pump is no longer pulling fuel due to the increase vacumn.
Replace your gas cap with a vented gas cap and it should work. Note to test this, take your gas cap off and then start your engine. I willing to bet that it does not die this time.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 10-13-2009, 04:19 PM   #3
cdowns
cdowns's Avatar
you probally have the wrong gascap for that year you should b running a vented cap// as far as starting did you set points plugs etc those things need to b done for a motor to run
Old 10-13-2009, 05:09 PM   #4
kc69
faulty sending unit. It showed I had a 1/4 tank of gas, when I was actually bone dry. The gasket around the fuel inlet was torn, so will replace it since I pulled it out. The cranking apparently built up pressure inside the empty gas tank..
Thread Tools
Display Modes
