Old 10-16-2009, 07:07 PM   #1
sonseeker
sonseeker's Avatar
Question Bucket seat conversion from stock bench seat
What seats are a direct fit with little to no mods. Is there an extensive write up on here somewhere? Pics would be nice,lets see yours.
sonseeker is offline   Reply With Quote
Old 10-16-2009, 07:40 PM   #2
JimKshortstep4x4
Re: Bucket seat conversion from stock bench seat
We swapped Blazer Buckets into my son's Burb. We used the seat track layout from a Blazer to locate the mounting holes and then made up renforcements for the weld nuts.
Non of the original holes could be used.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-18-2009, 06:58 PM   #3
sonseeker
sonseeker's Avatar
ttt,must be some others that have done this or about to?
Old 10-18-2009, 07:55 PM   #4
scott72
scott72's Avatar
bump..
I'm interested in this as well. =P
scott72 is offline   Reply With Quote
Old 10-18-2009, 10:12 PM   #5
D.PASSMORE
One of the First
D.PASSMORE's Avatar
67-68 buddy buckets will line up with existing holes for bench seat. If converting to 69-72 you will need to locte a original bucket truck for the exact location of holes or find a washd out truck cab / blazer tub and cut floor out and get all brackets (including front bucket brace) or just line it up using the "eyeball" method.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 10-20-2009, 06:06 PM   #6
sonseeker
sonseeker's Avatar
Thanks for the suggestions,any more with pics?
Old 10-20-2009, 09:10 PM   #7
leddzepp
Moderator
leddzepp's Avatar
If you are putting factory buckets in, you can re-use the outer mounting holes from the bench seat, and just drill new ones for the inner holes.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Thread Tools
Display Modes
