Old 10-17-2009, 06:28 PM   #1
zac
zac's Avatar
'79 10 bolt front questions
I'm using full-time 4wd for now (203) and my truck has some cheap lockouts on it I've been running in the locked position. I have the full-time stuff from a '72 dana 44. Gear, spring, cap for each side. The gear slides on the shaft and into the hubs. So adjust the wheel bearings, put in the spring and the gear, then the snap ring. Is that it? Also, I think the outer stub shaft from the dana 44 will interchange with the 10 bolt. Is that true? The splines on one side are very worn. Thanks
zac is offline   Reply With Quote
Old 10-17-2009, 07:20 PM   #2
LONGHAIR
Re: '79 10 bolt front questions
There is supposed to be a large cup-shaped "washer" that goes in before the spring. It keeps the spring from rubbing on the cage of the outer wheel bearing.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-17-2009, 07:28 PM   #3
msgross
msgross's Avatar
yes, the outer shafts are the same... the inner shafts aren't...
There are a lot of other shared parts too
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Thread Tools
Display Modes
