10-19-2009, 11:46 PM | #1 |
2004R trans with 3.08 axle
I'm looking at replacing my 69 C-10's TH350 with a 2004R. A guy at Phoenix Transmission said the highway RPMs would be too low in OD/lock-up with my 3.08 gears. Is anyone here running that combo? The engine is a mild 355. Tire height is 28.5".
I'm in the process of installing an Auburn posi, so now would be a good time to get 3.42 gears if they would work better. Only problem is I'd be committed to buying the OD trans once I installed those gears! The budget option is to keep the TH350 and go with 2.76 gears. That would drop highway RPMs by 10%, but low gear might be a little too tall for some situations.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 10-19-2009 at 11:49 PM. |
10-19-2009, 11:56 PM | #2 |
Re: 2004R trans with 3.08 axle
you'd b better with 373 and the overdrive
10-19-2009, 11:58 PM | #3 |
its all about the +6 inches
3.07 with the overdrive would kill MPG. I would go with the 3.73
10-20-2009, 12:01 AM | #4 |
i have that setup in my truck so far does good. but just got it going
72 swb pickup http://i124.photobucket.com/albums/p...k/100_0958.jpg 1967 chevelle ss 1966 mustang getting a l33 ls motor 1969 chevy dump truck 1989 mustang 6.0 ls best time of 1.29 at 5.91 https://www.youtube.com/watch?v=JtbooZoGZmQ |
10-20-2009, 12:02 AM | #5 | |
Roger "RUDE TOY"
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
10-20-2009, 12:30 AM | #6 |
Roger -- The 2004R is the same length as a TH350 w/ 6" tailshaft, so you don't have to mess with the trans cross member or get the driveshaft shortened. You will need a new TV cable and specific brackets for your carb. I didn't ask about trans cooling lines to the radiator, but I suspect they will be different. Phoenix Transmissions and Bow Tie Overdrives can tell you exactly what you need.
The OD ratio is .67 which will drop your highway RPMs by 33% -- and another 200-300 RPM lower when the T/C locks up.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 10-20-2009 at 12:32 AM. |
10-20-2009, 12:38 AM | #7 |
you'll have to move the crossmember to the TH400 position
trans cooler lines are in the same location The yoke is the same as a TH350, as is the shaft length as indicated above. do some seriouse research on TV cable setup, www.bowtieoverdrive.com is the best place to lean... and they have a great product too. Don't forget a lockup controler too. |
10-20-2009, 01:21 AM | #8 |
DAMN GUYS!
Thanks for the detailed info! Roger "RATIKLE"
10-20-2009, 07:48 AM | #9 |
sharp as a marble
I went to a site that has an RPM calculator, and here is what I did
255/70r15 tire is 29" tall 3.08 gear .67 OD should run 1500 at 65 mph. Now with that said, I would like that number on the highway. BUT, around town you might need to run it in 3rd gear. 3.42 would be my choice for a rear end gear. I have the above with a 3.73 in my truck, and FOR ME it seems the rpms are a bit high at 65-70. My trans is a 700r4 |
10-20-2009, 10:55 AM | #10 |
I am running a 700r4 with a 3:42 and probably a 28" tire.. 1800 at 60/65.. Love it!!!
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
10-20-2009, 11:53 AM | #11 |
Never Ending Projects
My '98 C1500 has 3.08 and a 4L60E (same ratios as a 700R4) and on the highway at 65+ it is great. Around town below 55, it sucks to be in 4th gear. Barely off idle but if you want to speed up, you have to get it to kick down to 3rd. I find around town, I just leave it in 3rd and never use overdrive. I save that for the freeway.
3.42's are very ideal, even 3.73's are a good choice. With a 200R4, since the first gear is not as deep as a 700R4 and the overdrive is a little better, I would rather have 4.11's then 3.08's. I think you will find 4.11's would give you better mileage as engines don't like to be lugged. My .02 worth.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
10-20-2009, 01:06 PM | #12 | |
Dave Dave
Dave & Marilyn in Rio Rancho NM....1967 Chevrolet C-10 long step side.....250 3 spd. ..... 1968 Chevrolet C-10 long step side.....325 hp 350 4spd.....3" Exhaust....etc. 1965 Chevrolet Suburban K-10....292 4spd....cam....etc. Bow Tie Baby |
10-20-2009, 03:35 PM | #13 | |
I'd LOVE to see it at around 1600 RPM, and I betcha my Gas Mileage would improve too! Roger "RATIKLE"
10-20-2009, 05:31 PM | #14 |
Not necessarily. It all depends on your setup, everything from the carb, cam, converter, etc. If you are lugging the engine, you can actually use more fuel because you end up using the throttle more to maintain speed because you are out of the power band. Most engines are most efficient when kept in the power band. Below or above it, you will typically use more fuel.
10-20-2009, 06:10 PM | #15 | |
10-20-2009, 06:22 PM | #16 |
I run 3.08 gears with a 700-r4. in a 70 stepside with stock 350 engine & 28 in. tires. 235-75.15. Love it. Pulls good & runs quiet. I keep it in 3rd around town to avoid excess shifting. I get 18 MPG in combination city/high.
There is one long hill on the interstate. The only time it will downshift is a strong headwind & the A/C on. Ive driven late model trucks on this hill that downshift every time. |
10-20-2009, 06:27 PM | #17 | |
10-20-2009, 06:55 PM | #18 | |
Roger "RATIKLE"
10-20-2009, 08:14 PM | #19 |
I forgot how great this site is. Incredible amount of info!
Some more questions: Will the T/C lock up in gears other than 4th? If you're cruising down the highway and step on the throttle a little, will the T/C unlock?
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
10-21-2009, 04:42 PM | #20 |
The TC lockup depends on what system you use. I get the vacuum switch off a late 80's van & hook it to ported vacuum. I use a pressure switch on the 4th gear pressure outlet. It only locks up in 4th gear with cruising throttle.
10-21-2009, 05:02 PM | #21 | |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 10-22-2009 at 02:33 AM. |
10-21-2009, 05:08 PM | #22 |
I understand the whole deal about keeping it in the torque band. But what you have to realize is there is a torque "curve" associated with the engine. Maybe your peak torque is at 2600 RPM for example. That doesn't mean you have to run it at 2600 on the freeway in order to hold your speed. You just need enough to overcome weight, friction, wind, etc. Maybe there is enough at 1800 RPM in some engines. So why not run it there, and just downshift if it loads up... It's a matter of knowing your engine.
10-21-2009, 05:44 PM | #23 |
Well, to use your example as a reference, you won't be running 1800 rpm even, with 3.08's of course. Not at or below 70 atleast. Go 3.42's for mileage, 3.73+ for fun
'72 cheyenne super step, '05 long bed gmc |
10-24-2009, 06:59 PM | #24 | |
In any case, I put it all back together with the 3.08 gears. No immediate pressure to spend the bucks on a 2004R, but will probably do it some day. And if my gearing is too tall, it's only a 10-12 hour job (for me on my back) to install 3.42 gears. I really appreciate all your comments.
10-25-2009, 07:49 PM | #25 |
GM ONLY BABY!!!
I have the 200-4r installed in my 72 GMC longbed, with a 355 sbc, .444 lift cam 1.94 int. valves, 600cfm Holley, nothing great, with the 3.07 rear gear and all is well. I bought all the parts needed from Bowtie Overdrives. I have 20" wheels, probably about 23" tire height. 65 mph is about 1900rpm. Good enough for me. I don't know what kind of mpg I am getting though.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up Last edited by chevydog66; 10-25-2009 at 07:50 PM. |
Thread Tools | |
Display Modes | |
