Old 10-21-2009, 10:34 AM   #1
Ackattack
Ackattack's Avatar
steering column seal
I'm getting ready to install my new van tilt steering column. I have a new seal and retainer, but it won't fit over the automatic shift linkage (not the handle).
Any suggestions before I cut it up.
Ackattack is offline   Reply With Quote
Old 10-21-2009, 11:23 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: steering column seal
Soon, I will be in the same boat and wondered that too. My guess is you have to disassemble the bottom part to get it to fit. I have been looking at ways to do it without cutting but unless you take the levers off, I am not sure how it would work.
Hopefully someone will enlighten us with an easier way. I am not looking foward to disassembling the column.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-21-2009, 01:25 PM   #3
CJJ67
This may not be the right way but I have a van tilt in my 67 stepside also. At the end of the steering column (the end that is in the engine compartment) is the lever (I think that's what it's called). Bend (gently) the lever up enough so that you can slide all the seals and other stuff over it, then bend it back. I used a small hammer to bend it. Again, it may be the wrong way to do it but it worked for me.
CJJ67 is offline   Reply With Quote
Old 10-21-2009, 05:03 PM   #4
mclairmo
I would not bend that lever. The metal will weaken and become more brittle.
mclairmo is offline   Reply With Quote
Old 10-21-2009, 06:39 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've bent a bunch of them. They bend back fine and never had one break yet.
Thread Tools
Display Modes
