10-26-2009, 09:24 PM | #1 |
Its a Truck Thing......
Coil Spring pinion adjustment shims
Has anyone found a place that sales shims to adjust the pinion angle for coil spring rear ends?????
have a 1 piece shaft and need to adjust the angle a little bit down, last hope would be to cut the welds and have it re welded. Any help would be appreciated. Thanks Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
10-27-2009, 11:14 AM | #2 |
Happy to be here
Re: Coil Spring pinion adjustment shims
Why can't you use shims where the trailing arms mount to the axle?
10-27-2009, 02:26 PM | #3 |
pretty sure that's what he is asking for ...
scroll to bottom http://www.stockcarproducts.com/trkarm1.htm Last edited by Shane; 10-27-2009 at 08:54 PM. |
10-27-2009, 08:04 PM | #4 |
Ask and you shall receive....
SHANE YOU DA MAN.....thats exactly what i have been looking for. I have called many and they screamed in horror with the thought of Coil spring shims..... Thanks Again Shane.. Smitty
10-27-2009, 08:15 PM | #5 |
thats good info
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
10-27-2009, 09:02 PM | #6 |
Like a Rock!
How do you determine the proper pinion angle on a lowered truck?
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! |
10-27-2009, 11:22 PM | #7 |
Happy to be here
Now I see...
10-28-2009, 09:29 PM | #8 |
With the engine and tranny installed, I found a place on the engine that was parallel to the crankshaft and took an angle measurement. I then adjusted my frame to the expected ride height. I then placed the gauge against the vertical surface of the rearend pinion. It was a 90 degrees difference from the tranny, just take that into account. Then, I adjusted the pinion angle until it matched the tranny.
11-17-2009, 04:58 PM | #9 |
this company doesn't make these shims any more.
http://www.stockcarproducts.com/trkarm1.htm Anyone know of another place? |
11-18-2009, 10:23 PM | #10 |
Back to square one.....
Smitty
11-18-2009, 11:38 PM | #11 |
Yup
11-19-2009, 05:37 AM | #12 |
CPP sells them in 1 through 4 degrees.
11-19-2009, 07:21 PM | #13 |
I bet they do.....
Smitty
11-22-2009, 07:07 PM | #14 |
Yeah they sell them but for $69 a pair. That is just pricey!!
11-22-2009, 07:26 PM | #15 |
Its not pricey, its ridiculous, thats why I am not interested in buying them.
Smitty
11-22-2009, 09:57 PM | #16 |
GM ONLY BABY!!!
I bought a pair from a local company. You could call them and maybe get them shipped. Fort Wayne Spring Service. (260) 424-6263 Or Google them.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
11-22-2009, 10:08 PM | #17 |
Cool, i will give them a ring. What did they charge? And these where for the coil spring rear and not the leaf spring, correct.
11-22-2009, 10:33 PM | #18 |
GM ONLY BABY!!!
Yes, for a coil spring rear. I swapped my GMC body to a Chevy frame in order to do the air ride. My receipt from the shop that installed them and did the alignment was $35, for the 6* shims.
11-23-2009, 02:24 PM | #19 |
well, called and no go. they only have them for the leaf spring rear
11-23-2009, 02:40 PM | #20 |
Well everyone, so far I only found 1 company that is still selling with exception to CPP. Hutch BSR has them. They are not on their website but if you call they say they have them. Not to cheap as well though, 3*= $26ea ($52 for the pair + shipping).
It is just amazing that no one carries these and not to mention how much they are trying to sell them for. It is just freakin metal (aluminum at that) |
11-23-2009, 10:12 PM | #21 |
Well its cheaper than CPP,,thats all that matters I guess, but your right effects66, its just metal, is it that hard to make?
Smitty
11-23-2009, 10:13 PM | #22 |
GM ONLY BABY!!!
What, no way. I just got a set for my trailing arm/coil rear back in May of this year.
11-23-2009, 10:22 PM | #23 |
GM ONLY BABY!!!
Do you have aluminum drop blocks? I had to have my drop blocks machined at an angle to get my pinion angle correct. My friend is a machinist and he charged my $0 to put a 2* angle on them.
11-23-2009, 11:45 PM | #24 |
No, I have the drop springs.
12-02-2009, 10:12 PM | #25 |
If anyone finds these, please drop a line...
Thanks Smitty
Thread Tools | |
Display Modes | |
