Old 01-19-2003, 06:42 PM   #1
Nick
2000 Chevy Rear End in a 69?? Will it work?
Hey Fellaz,
Im in the process of putting my 69 back together, but I need to get a new rearend or do a WHOLE lot of work to my old one. My current rear end is a 12 bolt, but has 373 and I want a 308 posi. Also I have a lot of brackets welded on top for my old air bag setup. I don’t want to carefully cut off all the old brackets (including the original trailing arm mounts) and have to replace the 373 with a 308 posi if I can simply replace the Whole thing with a new rear end out of a 99 or newer chevy. My only concern is whether the wheel base is the same length, and is the bolt pattern the same on my 69 six lug as the newer chevy six lugs. If you guys have any good info let me know..
>>Bagged69cheVY<< Nick George
Nick is offline   Reply With Quote
Old 01-19-2003, 07:16 PM   #2
MellowYellow70
123
Well I've seen and old 69 or 70 rolling around with the '99 and newer wheels, so I'd say the bolt pattern is the same. Measure wheel hub to wheel hub for both axles to see if they match. Otherwise I don't have a clue, also don't the 99 and newer rear ends use a disc setup? Which may require a different porprotioning valve. Good luck
If patience is truely a virtue, Then I am so screwed
1970 Chevy SWB 331 sbc and all the goodies. Under resurection
2001 Vette
MellowYellow70 is offline   Reply With Quote
Old 01-19-2003, 07:34 PM   #3
Cheyenne Super
I will try to check tomorrow
the part truck where i work had a rear axle go out and they just replaced it with a salvage unit. we still have the old axle laying in the junk pile. If I can remember I will measure the axle tomorrow. the front track is about 60 inches I believe the rear is approx. 58 I can't remember if those measurements are exact, it has been a while since I measured.
1971 Cheyenne Super
Soon to be converted to '68 front clip.
Efland, NC
Cheyenne Super is offline   Reply With Quote
Old 01-20-2003, 12:27 AM   #4
Stano
Stano's Avatar
The newer rear end is much wider! I have a 3.73 posi out of a 2000 with discs that I thought about using on my 67 til I realized how much wider it is than the 72 rear end I also had and ended up using. The 2000 rear end is $3250 from GM! Complete. I got it for hauling it off. And no its not stolen!
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80
Nice ride 67 Chevy C-10 LWB Built 350 TH-400
Wifes ride and family rig:
2001 Furd Expedition 5.4 Liter
Kickin back in Rolla,Mo. USA
"Do the thing you fear most and the death of fear is certain" Mark Twain
Stano is offline   Reply With Quote
Thread Tools
Display Modes
