Old 11-10-2009, 03:15 AM   #1
Hoffman65burb
Hoffman65burb's Avatar
Body lifts on these trucks
Hey,
Was wondering if i could see some pictures of people with body lifts, 2-3 inchs. Does it look goofy? can you see the frame rails alot like the 89-98 trucks? will i need to lengthen my steering or ebrake cables?
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Hoffman65burb is offline   Reply With Quote
Old 11-10-2009, 10:07 AM   #2
Jonboy
Slots go on anything!
Re: Body lifts on these trucks
It's just my opinion, but yes on all questions. You don't see a lot of people that take the time to put in a body lift correctly. I think a suspension lift is easier to do, but that's just my opinion.
Old 11-10-2009, 10:39 AM   #3
cochino12
It followed me home?
cochino12's Avatar
here is my old 73 with a 2" body lift and 285's, I hated beaing able to see the gap between the frame and body, and the rear bumper hung really low. Suspension lifts are cheap for these trucks, I would go with a 2-3" suspension lift personally
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 11-10-2009, 11:27 AM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Here's my blazer with a 3 inch body lift. I'm taking it out as soon as I get all the stock length bolts...
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 11-10-2009, 12:35 PM   #5
ghettoluxury
ghettoluxury's Avatar
3" body lift only
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 11-10-2009, 03:32 PM   #6
blown luv
I have a 3" body lift on my cc.Dont like the fact that the fuel tanks hang down were you can see them.
blown luv is offline   Reply With Quote
Old 11-10-2009, 07:26 PM   #7
Hoffman65burb
Ok, well i have a 4 inch lift on my jimmy,leafs no blocks, i just want to get a little 2 more inch's for looks and so it will look better iwth a bigger tire. Instead of getting new leafs up front and a block in back.
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Old 11-10-2009, 09:22 PM   #8
sailed2japan
Jonny
sailed2japan's Avatar
If done RIGHT, it can look good. I have put alot of thought into body lifting mine and here's my plan when I get the time. After installing the lift, move the gas tanks up to where they are still hidden by the body or install a suburban tank behind the rear axle and relocate the fuel door.
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 11-10-2009, 11:59 PM   #9
Broadband
Broadband's Avatar
Looks pretty good IMO either way -body or susp
"Political correctness is a doctrine,
fostered by a delusional, illogical minority,
and rabidly promoted by an unscrupulous mainstream media,
which holds forth the proposition that it is entirely
possible to pick up a turd by the clean end"
Broadband is offline   Reply With Quote
Thread Tools
Display Modes
