Old 11-11-2009, 12:44 AM   #1
Cruzin81
inline 6 to big block convertion
Whats all needed for a conversion to inline 6 to a 502? I know i will need to use big block engine mounts but are the holes already there? This is for a friend.
thanks Warren
Cruzin81 is offline   Reply With Quote
Old 11-11-2009, 07:29 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: inline 6 to big block convertion
Yes, all of the holes are in the frame. No mods needed at all on a 68-72 truck if you use proper big block mounts. 67 frame require some slight trimming of the top flange of the frame where the mount stands bolt down.
I have done two inline 6 to big block swaps. With planning and proper parts, it's nothing more involved than an engine change. I did have to lengthen the alternator wires since the alternator sits so low on an inline engine and up high on the big block. Bigger radiator and shroud are needed too of course. The holes are in the core support for the larger radiator to bolt right in.
Old 11-15-2009, 05:09 PM   #3
Cruzin81
Thanks, kinda what I figured but will pass on the info to my buddy.
Old 11-15-2009, 07:46 PM   #4
meangreen68
you gotta be kiddin!
meangreen68's Avatar
[I have done two inline 6 to big block swaps. With planning and proper parts, it's nothing more involved than an engine change.]
Hey TX Firefighter..
was wondering what size those BB's were? And do you know what mounts to use on a GenV 454?
It ain't easy being greasy!
meangreen68 is offline   Reply With Quote
Old 11-15-2009, 08:12 PM   #5
Tx Firefighter
1 was a 402 and the other a 454.
And I will be damned if I can justify why one of my heater hoses was red and the other black. Looks like hell. Kind of embarrassing in retrospect.
Old 11-15-2009, 08:32 PM   #6
meangreen68
you know, that engine is so sweet looking i hadn't even noticed the hose.
Old 11-15-2009, 08:58 PM   #7
mrh33916
Project '67 454
mrh33916's Avatar
Sweet Motor, more living proof that "THERE IS NO REPLACEMENT FOR DISPLACEMENT!!!"
mrh33916 is offline   Reply With Quote
Thread Tools
Display Modes
