Old 11-12-2009, 03:05 PM   #1
75sierraclassic
75sierraclassic's Avatar
Tire Air Pressure for 275/60/15
Hey guys, I wanted to see what you typically run for air pressure with a 275/60/15 on a stock 8" rally wheel. I have been running 30-32 lbs but they seem to be wearing more in the middle. Where should I be at for even wear?
75sierraclassic is offline   Reply With Quote
Old 11-12-2009, 03:30 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: Tire Air Pressure for 275/60/15
that means your running to much psi,,ill go look i got the same size tire
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-12-2009, 03:31 PM   #3
3r!c84
Badass
3r!c84's Avatar
35 psi is stock (says on the door)
-00 Saturn 5spd
1/4:13:90
Old 11-12-2009, 03:39 PM   #4
budgetstperformance
budgetstperformance's Avatar
i have the same size tire on some 8" wheels and i run 35psi. it is true that if you see the tire wearing more in the middle than on the sides it means they are over inflated but that seems highly unlikely that you are getting this type of wear pattern from 30-32psi. maybe your gauge is faulty?
budgetstperformance is offline   Reply With Quote
Old 11-12-2009, 03:47 PM   #5
Pyrotechnic
Pyrotechnic's Avatar
I inflated my BFG Radial T/A's of these size to 35 PSI which is the max. They did seem to wear out more in the center on the rear. I think this is because there's not enough of a load to flatten out the tire at this pressure. It's probably just something you will have to experiment with.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 11-12-2009, 05:27 PM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
This is somehting that I learned a few years back. Many tires with a soft rubber compound will balloon as you drive and wear in the middle. If you go with a tire that has a harder compound the wear will diminish.
I have found that the Cooper brand tires and the Mastercraft brand (made by Cooper) will last longer than the Goodyear or BFGoodrich tires. Just a matter of fact. I run my tires at 35 psi, so that I get the maximum out of my gas mileage and I also get reasonable tire mileage. I am presently running a Nitto brand tire on my trucks, but the winter tires are Mastercraft's. It is hard to beat them.
Frank
piecesparts is offline   Reply With Quote
Old 11-12-2009, 05:35 PM   #7
nlped
nlped's Avatar
If the tire is wearing in the middle, especially if it is more prevalent on the rear tires, reduce the tire pressure by 2-4 psi. This is typically the case with a tire that is "pushing" the limits of the wheel width and a light vehicle weight (i.e. the rear of a empty pick up).
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 11-12-2009, 06:04 PM   #8
BusinessProfessor
I use Coopers on all of my cars and have never had a wear problem. My truck will need new tires and I am going to the Coopers. Mine is a dump truck and I never thought about the psi and weight issue. It would be interesting to hear the follow-up.
BusinessProfessor is offline   Reply With Quote
Thread Tools
Display Modes
