11-14-2009, 11:57 PM | #1 |
Hub conversion Dana 44
I got a disc brake D44 for my 62 chevy build, it has automatic hubs, can I just pull the hub and rotor off a differen't D44 that has the manual hubs and swap them out??? Thanks, Larry
Also do the conversion hub kits for a ford Dana 44 work on the chevy axles??? Last edited by brew8; 11-14-2009 at 11:57 PM. |
11-15-2009, 04:14 AM | #2 |
Re: Hub conversion Dana 44
Just put locking hubs in unless you have an NP203 case than you will want to put the conversion in it to turn it into a part-time case. and all dana 44's have 19 spline outer axle shafts
1949 Five Window, 1973 Step Side, 2000 Z71 |
11-15-2009, 12:15 PM | #3 |
Thanks, Thats what I thought, cheers, Larry
11-15-2009, 12:17 PM | #4 |
One more question are the splines on the pinion the same? Can I use the pinion flange from the older axle for the new one to keep the same u joint that I have?? Thanks again
11-15-2009, 09:20 PM | #5 |
If it is a 44 yes.
11-15-2009, 10:14 PM | #6 |
Thanks again for all the help, larry
Thread Tools | |
Display Modes | |
