Junior Member
Rear Control arms?
I am replacing my ebrake cables and noticed the bushings on the rear control arms are dry rotted and cracked. Will I see any real difference in ride or handling by replacing these?
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! ![]() |
#2 | |
SSN 706
Re: Rear Control arms?
Getting the old stuff out & adding new poly bushings help eliminate some slop when transitioning into & out of corners. Definitely worth doing.
The poly bushings re-use the original shell so you just remove the rotted rubber. Pressing in new rubber bushings requires removing & replacing the entire bushing w/shell.
SSN 706
I took a torch and burned mine out in about 5 minutes.
Ooh That Smell...........
Junior Member
That would probably smell worse than pumpkin pie
Member of the longbed union.
that is a cool pic Bob, what Texas book is that.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
Junior Member
Not sure what book. It was in an email forwarded to me.
Didn't even pay attention to that part, although I can see why it might have caught your eye. No offense intended ![]()
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! ![]() Last edited by ol Curt; 11-19-2009 at 12:22 PM. |
Thread Tools | |
Display Modes | |
