11-25-2009, 09:41 PM | #1 |
1 Ton lift kit
Hey fellas, I have a 1979 1 Ton Dually 4X4 that I want to lift. I would like to put at least 35" tires under it. Does anybody make a 1 Ton specific lift kit and not use the 3/4 ton kits? I have seen alot of theses lifted on here and was wondering what kit they used.
Thanks in advance. |
11-29-2009, 11:43 PM | #2 |
Re: 1 Ton lift kit
When I did the conversion on my '76 crew cab, the lift was a bunch of trial and error. I do remember trying to find a 1 ton lift without much in the way of results. The only one I found was National Spring and they were pretty expensive. Not even sure if they are around anymore. I ended up going with a superlift 4" kit that used blocks in the rear and springs in the front. The tires I ran were Denman Coyotes ( I had 34.5" Swampers and they didnt wear well) that were in fact 36" tall and rode REALLY smooth.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
11-30-2009, 12:02 AM | #3 |
Currently Blazerless
Re: 1 Ton lift kit
National Spring Company is still in business and they make very high quality springs suited to what you use your truck for.
http://www.nationalsprings.com/products/?pID=101445
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
11-30-2009, 09:13 AM | #4 |
Re: 1 Ton lift kit
You can use 1/2 and 3/4 ton springs up front. Get heavy duty that way you can still use it as a 1 ton. Blocks will be fine for the rear.
Steering is the only major difference. 10 bolts and Dana 44s use a raised steering arm, Dana 60s use a block that raises the steering arm. National Tire and Wheel sells the Dana 60 block kit.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
12-01-2009, 06:31 PM | #5 |
Dually Pride
Re: 1 Ton lift kit
shackle flip out back, you keep you 1 ton springs. oh and if its a dually go with 9.00R16s
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually '94 Ford Ranger |
12-04-2009, 07:54 PM | #6 |
Re: 1 Ton lift kit
or search for what the CUCV gusy do...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
12-05-2009, 05:00 PM | #7 |
Re: 1 Ton lift kit
Depending on your tire size, you might need spacers in between your rear tires so they don't rub.
1995 GMC 4x4 1/2 ton 1999 Jeep Wrangler w/ 33's 68 camaro 350/350 1987 Chevy 3/4 ton 4x4 Suzuki DRZ 400s Dual Sport 1971 chevy long bed 2x4 194? Dodge 2.5 ton 1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455 1989 Chevy V30 crewcab dually 454/TH400 |
12-06-2009, 09:30 PM | #8 |
Re: 1 Ton lift kit
I agree with the shackle flip in the rear. Then fab to get the overloads to still function. Any of the HD kits front spring will work fine. Planning this same setup at some point on mine.
Thread Tools | |
Display Modes | |
