Old 11-27-2009, 04:10 PM   #1
bitchin85
bitchin85's Avatar
1 ton springs? need ideas
i have a 1/2 ton 2wd long bed and i want to run 31" bfg all terrains on it. what kind of lift would 1 ton or big block springs in the front give me? i want to do a small lift as cheap as possible so ill just be putting blocks in the rear. anyone have any other ideas on how i could get the front up 3 or so inches? thanks
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 11-27-2009, 04:25 PM   #2
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Re: 1 ton springs? need ideas
on my dually I have 31" tires on the front and they fit perfect. if you dont go wider than 9.50's they should fit just fine.
A better option though would be a spacer on the spring, because a 1 ton spring is going to ride way rougher, and you need to have your springs balanced from front to back, so if you put 1 tons in the front, you will want them in the back. Otherwise it will make your truck unstable.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 11-27-2009, 04:29 PM   #3
flamingbig10
6.0 powered square
flamingbig10's Avatar
you can fit 31s on a stock height truck
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 11-27-2009, 04:39 PM   #4
dbmx66
heres an easy 1 inch, there spring spacers, and really cheap.
http://www.stylintrucks.com/parts.as...tfamilyid=5260
dbmx66 is offline   Reply With Quote
Old 11-27-2009, 04:40 PM   #5
bitchin85
bitchin85's Avatar
i know i can fit 31s with the stock height but i wanted to lift it a bit to make them look less "crammed" into the wheel wells. whats with these spacers? are they any good?
easy to do?
Old 11-27-2009, 04:54 PM   #6
MrBeast
high-Tech Red Neck
MrBeast's Avatar
It isnt a bad job, but it is also not an ametur job, springs are dangerous, if you havent done em before get some one to help you, even when your suspension is at full jounce (down all the way) there is still load on the spring, and you pop that A-arm loose with out being supported properly, and that spring can unload, fly out and kill you.
Old 11-27-2009, 05:07 PM   #7
dbmx66
they dont look like they'd be hard, i'd say get all the tension out of the springs then put them in.
Old 11-27-2009, 05:24 PM   #8
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
You can use a rental spring compressor from O'rielly's or a place like that. Just be very, very careful when compressing the springs. If you have the compressors cocked, the spring will fly out and hit you or something. Just be patient and take your time while doing it.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-27-2009, 06:29 PM   #9
b454rat
My old truck had 31s on it, didn't look stuffed at all. I didn't want to put them at first because of that, then after they were on, wanted to keep it and maybe put some 32s on back and 31s on front. Sold instead.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 11-27-2009, 07:07 PM   #10
munger
munger's Avatar
my uncle put 1 ton springs in his 3/4 and it rode like a brick s***house and then my other uncle jacknifed it and its sitting in the pasture
munger is offline   Reply With Quote
Old 11-28-2009, 12:57 AM   #11
bitchin85
bitchin85's Avatar
so hhow much are these coil spacers? and do i need ball joint spacers and such? or anything else?
Old 11-28-2009, 01:08 AM   #12
MrBeast
high-Tech Red Neck
MrBeast's Avatar
No, you dont need a ball joint spacer, what the spring spacer does is it lifts the truck slightly by closing the space that the spring occupies, thus the same weight is displaced upward the ammount that the spacer occupies.
Also, you might consider a 4x4 conversion, parts to do it are easy to find, expecially if you stick with a half ton.
Old 11-28-2009, 01:12 AM   #13
bitchin85
bitchin85's Avatar
id love a 4x4 conversion.. if i had the money and time. its my dd so right now im stickin to projects i can knock out in a weekend tops. and arent the frames diferent from 4x4 to 2wd?
Old 11-28-2009, 01:35 AM   #14
longbedrick
longbedrick's Avatar
http://universalcarlifts.com/index.p...702a6c4a2a0975
I just happened accross this a while back.
longbedrick is offline   Reply With Quote
Old 11-28-2009, 01:41 AM   #15
AceX
>130dB Moderator
AceX's Avatar
Just thinking out loud;
Would a 3/4t spindle provide a lift?
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 11-28-2009, 01:48 AM   #16
KQQL IT
At the body shop.
KQQL IT's Avatar
My dad used to use 3/4 ton van coils for pre runner back in the day. And ive seen a few 3/4 ton suburbans that are very tall
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 11-28-2009, 01:49 AM   #17
bitchin85
bitchin85's Avatar
that kit would be nice but its 500 dollars. im trying to go as cheap as possible with this. i plan on making the lift blocks and if i can get measurements im sure i could make the coil spacers too. anyone know how much they are btw?
Old 11-28-2009, 02:38 AM   #18
dbmx66
the spacers? check my post up a little there 40 something on stylin trucks i believe
Old 11-28-2009, 02:42 AM   #19
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Man for 500.00 you should be able to get a donor truck and make yours a 4x4
Old 11-28-2009, 02:44 AM   #20
bitchin85
bitchin85's Avatar
o sorry i didnt see that link. they only give me an inch of lift though.. i want like 3 inches. or is that just not gonna happen for cheap? if i could measure one of those spacers out i could make them 2 or 3 inches thick out of aluminum or steel but would that screw something up? bear with me if some of what i say is a little dumb.. im new to suspension stuff
Old 11-28-2009, 02:50 AM   #21
KQQL IT
At the body shop.
KQQL IT's Avatar
Cant get cheaper than junkyard?
Old 11-28-2009, 02:52 AM   #22
bitchin85
bitchin85's Avatar
i could get those easily. there are about ten good yards within 20 minits of me that have a ton of these trucks laying around. how much lift would a 3/4 ton burban spring give me? and would everything bolt right up?
Old 11-28-2009, 02:55 AM   #23
KQQL IT
At the body shop.
KQQL IT's Avatar
Yeah 3/4 ton suburban with 454 would be your best bet and work perfect. And probably 2" or so
Old 11-28-2009, 02:57 AM   #24
MrBeast
high-Tech Red Neck
MrBeast's Avatar
To achieve what you want to with a spacer is really not going to happen. you would also have to have a spacer on your lower A-arm, and custom upper A-arm to make it all work, you are talking about major rebuilding of yoru suspension.
Now consider this, you can mount ALL of the suspension brackets on to your frame for a 4x4 conversion with out removing any of your 2wd components!
The big job will be pulling the engine cross member, and installing the 4x4 one. Your truck would be down for about a week, maybe 2, less if you have good help.
If you play your cards right I am sure you can get a 4x4 front suspension for a half ton with the frame, of not the whole truck attached to it for little to nothing.
You dont have to install the t-case, you dont have to have a front shaft in to drive it, you can do that later.
I think for your application and in your neck of the woods, having a 4x4 would make your life so much easier, and the work to do it would be easier than lifting your truck as a 2wd.
And so you know where I am coming from, I have been wrenching on old chevys for about 16 years now, I also have a welding degree, and I am going to school to be a CNC machinist.
Good luck with your build, you should really get a thread going, you will enjoy it. - nick
Old 11-28-2009, 02:58 AM   #25
bitchin85
bitchin85's Avatar
how much lift would it give me? would it make it ride real rough? i dont realy care how it rides, i know its not a cadillac, its an old truck, but im just wonderin
Thread Tools
Display Modes
