01-22-2003, 09:32 AM | #1 |
rear end swap?????????????
will the rear end from a 86 3/4 ton bolt right under my 70 3/4 ton?
01-22-2003, 10:15 AM | #2 |
Fabricate till you "puke"
Is your 70 leaf or coil?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-22-2003, 02:56 PM | #3 |
my 70 has leafs on the rear
01-22-2003, 03:03 PM | #4 |
I think you will find the spring pads to line up on the 2wd trucks, but will need to weld on the shock mounts from the 70. good luck....crazyL
01-22-2003, 03:04 PM | #5 |
KEEP ON TRUCKING
my 72 has leafs and i had a 76 rear put in it i cant rember but i think it was something he cut off and swapped sides or something but its not a direct bolt in but will fit with minor mods maybe someone else knows more
72 cheyenne 2wd lwb 71 k20 sons bassett va |
01-22-2003, 04:33 PM | #6 |
Cantankerous Geezer
Measure the drum to drum distance. They're not all the same.
Fred There is no such thing as too much cam...just not enough engine. |
01-26-2003, 11:40 PM | #7 |
the rear end i have is a 14 bolt corp with 4.10s. i dont think it a full floater but i havent looked to make sure yet and it has the cone shaped drums. it does not have a posi unit. is it possible to put 9/16 lug studs in the 70 axles? if so i might just leave it where is at
01-27-2003, 03:03 AM | #8 |
if its full floater then it wil have the hubs that stick out about 2.5" that the ends of the axle shafts bolt onto(to the drums)
if its from a 73-80 then its an FF could have 9/16" studs put in if you have a shop centerdrill the 1/2 holes out to 9/16" or swap in 9/16" studs axle shafts good luck |
01-27-2003, 11:16 AM | #9 |
rusted chevy, he has a full floater axle, so studs are not in the shaft.
Pull your axleshafts, remove the hubs, and have a local machine shop drill them for an interference fit for 9/16 studs you buy at the parts store. You can hammer the old studs out, but take at least one so the shop can measure the amount of interference before drilling the new holes. Obviously they should have the new ones as well... Another option is getting the hubs off of a 71-72 truck and swapping those on to your truck.
01-27-2003, 03:35 PM | #10 |
i looked at the donor rear in the 86 and its not a floater. the axles look just like the ones on my 1/2 ton but have 8 lugs. i havent got the 70 home yet to look at it but when i do i will post it then go from there.
01-27-2003, 04:48 PM | #11 |
The 70 will be a full floater, as posted above.......unless it has been changed by a former owner. ....crazyL
Thread Tools | |
Display Modes | |
