Old 11-28-2009, 01:30 AM   #1
Raider Rudy
Raider Rudy's Avatar
4x4 Manual to Auto
I have a 64 Chev 1/2 ton short bed 4x4 with a standard trans (4 spd) & a divorced transfer case. I'm putting in an automatic (turbo 350). Can I keep the divorced transfer case or will I have problems?
1969 Chevy Long Fleet Custom C/10 (2nd owner)
1971 Chevy Short Fleet Custom C/10 (2nd owner)
2001 Chevy Silverado Ext Cab
Raider Rudy is offline   Reply With Quote
Old 11-28-2009, 09:39 AM   #2
Re: 4x4 Manual to Auto
I can`t say for sure.But,usually having a divorced case makes it possible to go about any way you want with a transmission.I`m thinking you can.
Old 11-28-2009, 10:54 AM   #3
ghettoluxury
ghettoluxury's Avatar
You can keep it, but you might have to have a new driveshaft made from the tranny to the case
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 11-28-2009, 11:47 AM   #4
Raider Rudy
Thanks! I'm trying to get it going before New Years
Old 11-28-2009, 11:48 AM   #5
Raider Rudy
Right On!
Old 11-29-2009, 11:33 PM   #6
'63GENIII
'63GENIII's Avatar
I run a 400 with a Rockwell. It had a 4 speed originally. I just picked up a 700r4 for use with a divorced np205 out of an international that is being picked up tomorrow. I like the thought of divorced t-cases for testing out different transmission options. Just curious, are you going to find a column shift set up with the gear indicator or use a cable shift set up? If you're using the column, what are you getting the steering column out of?
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 12-01-2009, 12:19 AM   #7
Raider Rudy
Thumbs up Re: 4x4 Manual to Auto
I'm going with a column shift set up & I'm going to use a steering column out of my brothers 1971 Cheyenne
Thread Tools
Display Modes
