11-28-2009, 09:09 PM | #1 |
Body Flex
After replacing body mounts seems to be a lot of body flex or role in my 71 2 wd. As you drive the gap between the doors and body will get bigger and smaller as the blazer is driven. rocker boxes look to be in great shape. Little to no rust, small amount on the lower drivers door post. I used cheep Taiwan after market mount would neoprene rubber mount help. Any ideas would be appreciated.
Thanks Rick Last edited by reefer55; 11-28-2009 at 09:10 PM. |
11-29-2009, 12:46 AM | #2 |
Re: Body Flex
its like an el camino lets say, the tub is long enough to need to flex like that. I have had lots of early broncos, and once I was checking the flex between the door and body with finger while driving; bad idea. Huge blood blister. The broncos would flex so much that if the doors are misaligned that they would hit the tub itself. I would say the blazer is similar. Although I use the poly mounts myself, not by choice, but they are usually easier to come by ie. energy suspension etc. Hope this helps.
James |
11-29-2009, 08:06 AM | #3 |
Re: Body Flex
That doesn't sound normal to me, are they torqued down correctly?
Did you do all 5 position's including the rad. core support? Where did you purchase these mounts from? |
11-29-2009, 01:58 PM | #4 |
Re: Body Flex
Thanks guys, Yes all the mounts were replaced and they came from LMC they weren't very expensive. Over the winter up here I'm going to change them and put the good polyurethane ones on and repair the door jam.
Any help on a supplier for the good rubber mounts? |
11-29-2009, 02:09 PM | #5 |
Re: Body Flex
Going poly may not neccessarily the answer, with the correct O.E.M. style body mounts, it should be pretty stable on the road.
...course if your trying to corner like a Ferrari, that may not be the case either. |
11-30-2009, 10:22 AM | #6 |
2WD Jimmy
Re: Body Flex
I can only speak for myself, (mine is 2wd). Before we removed the body, if you jacked it up uneven, you couldnt shut (or somtimes open) the doors. The body is back on the frame now, but the doors are still off until the wiring and underdash stuff is done. We put in a roll cage to lessen the twist. Of course a big motor is also the issue here.
11-30-2009, 01:15 PM | #7 | |
Re: Body Flex
Thing is these frames were 'designed' to flex from the beginning, just trying to say poly mounts might not cure it...dunno. |
11-30-2009, 02:19 PM | #8 |
Future TOTM Winner
Re: Body Flex
You bring up a question I have had for years AND it happens to pertain to this post. When these blazers were brand new from the factory, did they flex so much that the doors wouldn't open? Seams like even when someone restores one it it's still an issue at least to a degree. I have a hard time believing it was that way from day one, but maybe so. Can any of you guys that had one new back in the day shed some light on how they were 30 years ago?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
12-01-2009, 01:37 AM | #9 |
Re: Body Flex
That's probably one of the reasons that the K5 Blazer went from full convertible to a steel cab spanning the door openings after 1975 (along with the safety from roll-over issue, and top leak issues).
12-01-2009, 08:23 AM | #10 |
Re: Body Flex
Thanks again for the replies. My nefew has a 72 2wd and his body seems to be much more stable than mine and his is all original nothing has been changed yet. I think once I get it up in the air I will loosen the top ensure the doors are aligned and re-tighten the top and than change the mounts. So can some one direct me to poly mounts?
12-01-2009, 10:11 AM | #11 | |
2WD Jimmy
Re: Body Flex
Im guessing VTBlazer is right on this one... we will see I guess. Last edited by Tom Vogel; 12-01-2009 at 10:14 AM. |
12-01-2009, 05:02 PM | #12 |
2wd FTW!!!!
Re: Body Flex
Thread Tools | |
Display Modes | |
